• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    moveable links
    221 Views, 7 Replies
    12-24-2012 05:10 AM
    I have a link.. How do i mate these links together so as the chain is moveable in all directions..
    SAm
    Please use plain text.
    Re: moveable links
    12-24-2012 05:49 AM in reply to: sam__gleeson
    How many total links?
    Contact sets might work for a few links
    mated workpoints will allow more links, but restricts some of the DOF
    Dynamic Simulation could be an option, but again - more than a few links is going to drag your machine to it's knees.
    What is your true design intent.
    The more DOF you can remove the easier for the computer to solve.
    Active Contributor
    Re: moveable links
    12-24-2012 05:58 AM in reply to: JDMather
    approx, 30 links per chain
    A steel box with a chain on each corner connecting to a larger ring...actually does not need to move....i need to make 4 chains (each 30 links) .. each chain attaches to a corner on the steel box and then all 4 chains held together a the top on a large ring
    Sam
    Re: moveable links
    12-24-2012 09:45 AM in reply to: sam__gleeson
    That description sounds like all DOF can be removed.
    Place workpoints where the insides of the links would be tangent (tangent constraint would be more complex than needed.
    Constraint the workpoints.
    Add constraints to origin workplanes between links to make them perpendicular to each other.
    I would probably simplify by pattern Feature as body in single part rather than do these as individual parts.
    Active Contributor
    Re: moveable links
    12-27-2012 04:24 AM in reply to: sam__gleeson
    I followed your advice and came up with these files.
    How do i progress to the following
    1. adding the 4 chains to the links on the frame and then the chains connected on to the centre Ring
    Regards
    Sam
    Active Contributor
    Re: moveable links
    12-28-2012 06:33 AM in reply to: sam__gleeson
    Hi
    need help with ;last stage of adding the chains to the bracket and ring.Anyone?
    Thank you
    Active Contributor
    Re: moveable links
    01-05-2013 04:06 AM in reply to: sam__gleeson
    Hi
    I am having trouble getting the 4 chains to connect to the ring.Can someone help me out here please?
    Sam
    Active Contributor
    Re: moveable links
    01-08-2013 05:06 AM in reply to: sam__gleeson
    someone/anyone.I need help placing the chains onto the frame and ring.I have tried but it is not working.Please help
    Sam
    IV 2013 EDU
