• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    modifying diameter and radius dimensions
    344 Views, 4 Replies
    10-23-2012 09:56 AM
    My company is trying to Standardize all drawings produced to 1 format.  the one we are attempting to create would be in the form of: nominal upper limit^lower limit.  this is easily acheived in autocad and linear, chamfer, and hole/thread dimensions in inventor.  but radii's and diameters from a round surface (as apposed to linear diameters) we have run into a snag with.  We cannot seem to find a way to either remove the prefix symbols or be able to insert text between the symbol and tolerance.
    below is a illistration of the problem and the form of the new dimensions.
    if anyone knows where i can find these controles, the information would be much appreciated.
    Please use plain text.
    *Expert Elite*
    Re: modifying diameter and radius dimensions
    10-23-2012 12:26 PM in reply to: jbellric
    jbellric wrote:
    My company is trying to Standardize ....
    What standard are you using?  (Example - ASME/ANSI Y14.41).
    Inventor Professional 2014 Edu 64-bit
    10-23-2012 12:30 PM in reply to: JDMather
    we aren't really using a set ANSI standard right now.  every engineer has his own method right now.
    *Expert Elite*
    10-23-2012 01:52 PM in reply to: jbellric
    Perhaps the easiest way to introduce and enforce a common standard is to agree to use a National Standard.
    10-23-2012 02:19 PM in reply to: JDMather
    I have been trying for the last 3 years but this is what the management feel is our better option.  so back to the original question: Is there a way to remove the diameter and radius symbol from appearing on their own?
