• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    missing part mi_11a_003 Starting out - "Mastering Autodesk Inventor 2012"
    137 Views, 4 Replies
    11-07-2012 12:35 PM
    Hi
    I am a technician attempting to fix this problem for a tutor.
    I have missing parts on only one tutorial file as downloaded from sybex downloads
    On mi_11a_001_done.iam the bolt nut and washer were unresolved, so I used 7zip to dump all files in the same folder- by default windows 7 unzipper put them in seperate chapter folders which appeared to break the parts links.
    On this example by clicking "content centre" on the left part of the open dialog box the 3 parts were then found. This appears to be my custom content.
    On mi_11a003.iam The parts are not resolvable, searching the entire folder for *part* reveals nothing, have I missed a dependant zip download? Or some parts to add to my library at the start?
    Open attempt
    http://iforce.co.nz/i/wxwrd5pa.wq2.png
    Result
    http://iforce.co.nz/i/op5vlu4g.hqn.png
    All the other tutorials load fine!
    My Content centre is set to programdata\autodesk\Inevntor 2012\content centre\libraries - where large files are present, and items can definately be placed from the content centre into a project.
    My issue is close to this one -
    http://forums.autodesk.com/t5/Autodesk-Inventor/Starting-out-Sybex-quot-Mastering-Autodesk-Inventor-...
    Many thanks
    Please use plain text.
    Valued Mentor
    swordmaster
    Re: missing part mi_11a_003 Starting out - "Mastering Autodesk Inventor 20
    11-07-2012 01:09 PM in reply to: airdrieelliston
    Had the same problem with mi_11a_003
    I sent this to the publisher/author on 9/26/12 ..........never recieved a reply
    Working my way through the design accelerator (chapter 12) of your book
    On page 498 I am asked to open an assembly mi_11a_003 when i try to do so there are two files missing named
    Part2
    Part3
    Presumably they are missing from the download package
    I can just create my own versions of these,however I thought i would let you know
    Inventor 2010 Certified Professional
    New Member
    11-07-2012 01:13 PM in reply to: swordmaster
    Hi
    Yep I thought I would just re create them ,but I dont know what they are. I realise aslong as we can perform some calculations on the joint/bolts etc thats all that matters.
    Distinguished Mentor
    11-07-2012 01:50 PM in reply to: airdrieelliston
    Valued Mentor
    swordmaster
    11-07-2012 01:55 PM in reply to: airdrieelliston
    here are the parts i created
