• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    long time to execute undo or redo command Inventor 2012 sp2
    253 Views, 18 Replies
    01-15-2013 03:50 PM
    I am running Inventor 2012 sp2.
    Even with a simple IPT that only has a handfull of features, at times it takes a long time (3-5 minutes, sometimes longer) for Inventor to execute a undo or redo command.
    Undo file size setting in Application options is set at 1MB (which is teh same setting I used in previous versions).
    I haven't seen this issue before, but now after a receint upgrade to Invetor 2012 from 2010, I am now seeing an issue there.
    Any fixes?
    Please use plain text.
    Employee
    stanislav.sedlak
    Re: long time to execute undo or redo command Inventor 2012 sp2
    01-15-2013 11:51 PM in reply to: recordsj
    Could you attach the part file for further investigation?
    Stanislav
    Valued Contributor
    01-16-2013 07:22 AM in reply to: stanislav.sedlak
    the issue hasn't been file specific, I have had this issue occur on a lot of files.  Other people I work with have been experiencing the same issue.
    Distinguished Mentor
    -niels-
    01-16-2013 07:48 AM in reply to: recordsj
    Is it really at 1 MB or is that a typo?
    We have our undo file size set to 1024 MB so inventor actually has some memory to undo stuff.
    Does the speed improve if you increase your setting?
    (i believe the default was 256)
    Using IV2013 Pro SP1.1, Win7-64bit
    Valued Contributor
    01-16-2013 07:53 AM in reply to: recordsj
    It is at 1024 MB.  See screenshot below
    -niels-
    01-16-2013 07:59 AM in reply to: recordsj
    ah ok, typo...
    Anyway, do you see any difference when you change that size (up or down)?
    Could there be anything else interfering, like antivirus or such?
    I'm on 2013, never used sp2 for 2012... so can't say if it could be related to that...
    *Expert Elite*
    Curtis_Waguespack
    01-16-2013 09:02 AM in reply to: recordsj
    Hi recordsj,
    Just a thought, but if you go to the Tools tab > Application Options button > File tab and look at the Undo file location option, you might try changing that to a different location (network location vs. local location) to see if that changes anything.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    01-16-2013 09:07 AM in reply to: Curtis_Waguespack
    It is already pointing to a local folder on the hard drive for the undo.
    02-07-2013 10:17 AM in reply to: recordsj
    Are you using ctrl+Z and ctrl+Y to undo and re-do, or are you using the menu icons?  I have noticed that some commands take longer with the keyboard than with the menu for some reason.  I'm not sure what service pack it started with; but it is definatly something I see in 2012.
    Valued Contributor
    02-07-2013 10:20 AM in reply to: jfleeger
    I use the menu icons.
