Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Farstad, Roger
iparts fasteners. ..
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
58 Views, 8 Replies
11-10-2002 09:07 PM
In R5 we did built our own fastener library and added the following path's
to the project files
Library Search path:
Fasteners = ....\Fastener_factory
_Fasteners=...\Fastener_iparts
Our problem is that in R6 all library parts are read only, and if we moves
the path to Work Group, IV don't understand the _Fastener.
Please help, we are stuck on this problem.
Roger
Roger
*Dotson, Sean
Re: iparts fasteners. ..
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2002 09:26 PM in reply to:
*Farstad, Roger
Why would you want to move them to workgroup paths for all projects?
If you want to edit the ipart factories make a new project that refers to
the directory as a workspace path...(and keep them as library for all other
projects)
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Roger Farstad" wrote in message
news:58427D523D7733FBFD6EDB7DC24FB148@in.WebX.maYI adrTaRb...
> Roger
projects)
Sean Dotson, PE
"Roger Farstad"
> Roger
*Farstad, Roger
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2002 09:30 PM in reply to:
*Farstad, Roger
The problem occure when we try to change the size of the bolts. For instance
from M10x40 mm to M12x60mm
Then you will need write access.
Roger
"Sean Dotson" wrote in message
news
C815CEFC6F9746E0623649E5C8A0354@in.WebX.maYIadrTaR b...
other
> projects)
> Sean Dotson, PE
path's
moves
> > Roger
Roger
"Sean Dotson"
news
other
> projects)
> Sean Dotson, PE
> "Roger Farstad"
path's
moves
> > Roger
*Dotson, Sean
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2002 09:44 PM in reply to:
*Farstad, Roger
R6 doesn't prevent you from writing to the proxy path (the _Fasteners path).
It only prevents changes to the parts in the factory location (Fasteners
path). Perhaps you do not have write access on a disk or network level that
is causing this (external to Inventor). I have my paths set up very similar
to yours and it presents no read/write problems.
Sean Dotson, PE
news:1207868F8C7E2779C1FFAA88E123F7F0@in.WebX.maYI adrTaRb...
instance
> Roger
> news
to
> other
> > projects)
> > Sean Dotson, PE
> path's
> moves
> > > Roger
Sean Dotson, PE
"Roger Farstad"
instance
> Roger
> "Sean Dotson"
> news
to
> other
> > projects)
> > Sean Dotson, PE
> > "Roger Farstad"
> path's
> moves
> > > Roger
*Farstad, Roger
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2002 09:48 PM in reply to:
*Farstad, Roger
OK
I don't know whats happening, but when the users tries to change the size of
a inserted bolt, the name changes but the not the fysical model.
There are also added a ! sign at the beginning of the name of the bolt.
Roger
news:C522CB4DFAEFA3E69C3D350102D6A032@in.WebX.maYI adrTaRb...
path).
that
similar
> Sean Dotson, PE
> instance
> > Roger
> > news
> to
> > other
> > > projects)
> > > Sean Dotson, PE
> > path's
> > moves
> > > > Roger
Roger
"Sean Dotson"
path).
that
similar
> Sean Dotson, PE
> "Roger Farstad"
> instance
> > Roger
> > "Sean Dotson"
> > news
> to
> > other
> > > projects)
> > > Sean Dotson, PE
> > > "Roger Farstad"
> > path's
> > moves
> > > > Roger
*Farstad, Roger
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2002 10:02 PM in reply to:
*Farstad, Roger
A second question regarding fasteners.
The built-in library of nuts and bolts, from which template do they get
their materials. It is not the default template catalog defined in appl
options.> files
Roger
> Roger
options.> files
Roger
"Roger Farstad"
> Roger
*Dotson, Sean
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2002 10:09 PM in reply to:
*Farstad, Roger
That means that the child is out of date with the parent. Did you try to
place this child when you had the ipart paths in the workspace? If so then
it's probably reference the wrong ipart child. I bet you $ to doughnuts
that if you tried to place a part when you had Fasteners=..//ipart factories
as a workgroup path there is a folder under this directory where the ipart
child is stored. If so then close the assy. Delete this child and folder.
Now reopen the assy with the paths in the library path section and you'll
have to repoint the iparts to the correct children (or if it's just a few
delete them and replace them)
If you didn't place any children while the paths were in the workgroups area
then.....
Was this a new row that was added to the ipart recently? Possibly there is
an error in the ipart table. Can you post it to CF and I'll have a look.
Sean Dotson, PE
news:BFAC411193BFC729A5FA1BB91507B5B7@in.WebX.maYI adrTaRb...
> OK
of
> Roger
> path).
> that
> similar
> > Sean Dotson, PE
> > instance
> > > Roger
> > > news
refers
> > to
all
> > > other
> > > > projects)
> > > > Sean Dotson, PE
following
> > > path's
we
> > > moves
> > > > > Roger
then.....
Sean Dotson, PE
"Roger Farstad"
> OK
of
> Roger
> "Sean Dotson"
> path).
> that
> similar
> > Sean Dotson, PE
> > "Roger Farstad"
> > instance
> > > Roger
> > > "Sean Dotson"
> > > news
refers
> > to
all
> > > other
> > > > projects)
> > > > Sean Dotson, PE
> > > > "Roger Farstad"
following
> > > path's
we
> > > moves
> > > > > Roger
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2002 10:43 PM in reply to:
*Farstad, Roger
You can`t add material to the Built in Library Parts in R6
SORRY!!
regards Svein
SORRY!!
regards Svein
*Farstad, Roger
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-11-2002 02:17 PM in reply to:
*Farstad, Roger
If this is the reality, the hole library is useless
for us. We make fabrication drawings where the material is
important.
important.
I can hardly belive this.
Roger
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Svein" <svein@ags.no> wrote inYou
message
href="news:f121f01.6@WebX.maYIadrTaRb">news:f121f01.6@WebX.maYIadrTaRb...
SORRY!!
regards Svein
