• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    inventor crashing when inserting from vault,
    119 Views, 4 Replies
    12-31-2012 07:13 AM
    Hi all
    i got a good one, just installed 2013 and vault upgrades,  and all WAS fine until we found a issue.  If i trying opening a MODEL (ASSEM OR PART) from the vault server, (not locally), it will work....yeah.....NOW if i do the same thing BUT browser down 3 sub folders, it will crash....fo example,  if i browse to ....\Railpower Projects\New Nomenclature\HARDWARE CATALOG\CATALOG B\B007.  choose any part...poof.. good bye inventor.  This happens at any folder at 3 levels deep...with any part or assembly.  we have do this with about 100+ senerios - different parts - different assemblies. the only thing constant is after going 3 folders deep (or more) it will crash - thanks
    Please use plain text.
    Re: inventor crashing when inserting from vault,
    01-02-2013 05:26 AM in reply to: Sean
    Have you tried to create a new project file?
    Member
    01-02-2013 07:14 AM in reply to: Are_42
    we tried just tried it, no luck.  We have a ticket in, but nothing yet
    Member
    01-15-2013 06:07 PM in reply to: Are_42
    We just tried it, nada. we hoped that even though the old had been migrated it would work from scratch. But it didn't. thanks for the suggestion Sean
    Active Contributor
    chrisrodway
    01-16-2013 01:24 AM in reply to: Sean
    Have you installed the vault service pack from dec 2012, that solved alot of problems for me
    Hope that might solve your crashing problem
    Chris
    Design Engineer
    Sheffield UK
    Cheers
    Chris Rodway
    Design Engineer
    Sheffield, UK
