• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    inventor 2010 add-inns not there
    120 Views, 4 Replies
    10-24-2012 09:08 PM
    Hi Y'all
    Ex AutoCad,SolidWorks user looking at Inventor.
    Loaded 2010 up to SP4. Add-ins appear to be in Bin folder and show as loaded in Tools/Add-in manager but do not show in Add-in list on the Ribbon.
    Tried online autodesk fixes with no luck.
    Hope you can help
    kiwicadman
    Please use plain text.
    Member
    Re: inventor 2010 add-inns not there
    10-25-2012 01:51 AM in reply to: kiwicadman
    Now when I add in after opening the Stress Analysis tool bar lights up but then goes grey again.
    Rob,
    *Expert Elite*
    10-25-2012 12:15 PM in reply to: kiwicadman
    kiwicadman
    This has come up here several times - a search might turn up the solution.
    What was the url of the Autodesk "fix" that you tried?
    Inventor Professional 2014 Edu 64-bit
    *Expert Elite*
    Curtis_Waguespack
    10-25-2012 01:25 PM in reply to: kiwicadman
    Hi kiwicadman,
    If one of these is what you've tried, you might try the other:
    Inventor add-in repair utility
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404176&linkID=9242018
    How to Register your missing Add-Ins
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13909656&linkID=9242018
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    10-25-2012 03:38 PM in reply to: Curtis_Waguespack
    Hi Curtis:
    Yes I did try the drop in file. Coppied the contents into a txt file, changed it to cmd, placed it in the bin folder and ran it,
    I don't remember from the old days how to do the dir thing to navigate in DOS.
    I assume that both fixes do thesame thing.
    JD has sujested a clean uninstal/reinstal.
    Thanks.
    Rob
