Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
internal error in persistenc e operation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have an iassembly that will open just fine, but when I try to change configurations, I get the joyful, "Internal error in persistence operation (Segment loading is not supported within other persistence operations)" dialog. It pops up twice, IV thinks, then crashes.
Everything about this error says it's a corrupted file or that there's a derived sketch issue. It was built in early 2012. I've used it since with switch to 2013. Recently, I haven't been able to get it to work.
I deleated the only extrusion in the assembly level, and coul change configurations with out error. I rebuilt the sketch/extrusion, and now it fails again.
Any advice or knowledge? I have two other assemblies built with the same parts, and the same cut, and they (/knock on wood) work fine.
Re: internal error in persistenc e operation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would lig a support request with Autodesk and submit the files. If you have the R2012 versions along with 2013 versions they can test it out and log to development if needed.
Don
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have, now.
Thank you.
