• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    nikhunter
    Re: ilogic shortcut key
    11-30-2012 03:33 PM in reply to: Ktelang
    Is ti strange that in macros category i dont have nothing.....:smileytongue:
    How can i enter a Key in a column at macro category??
    Please use plain text.
    Employee
    11-30-2012 03:37 PM in reply to: nikhunter
    Did you put all your VBA code into your ApplicationProject?
    It must be in the ApplicationProject, instead of in the document.
    Mike Deck
    Software Developer
    DLS - Mechanical Design
    Autodesk, Inc.
    Active Contributor
    nikhunter
    11-30-2012 03:41 PM in reply to: MjDeck
    I forgot to tell you tha i am amatuer at Autodesk Inventor...
    How can i  put all  VBA code into my ApplicationProject
    Employee
    11-30-2012 03:48 PM in reply to: nikhunter
    Here is a screenshot of the VBA Editor.  The ApplicationProject is at the top left.  Copy and paste your code from where you have it now (maybe in Module1 of the DocumentProject) into Module1 of the ApplicationProject.
    Mike Deck
    Software Developer
    Autodesk, Inc.
    Active Contributor
    nikhunter
    11-30-2012 04:00 PM in reply to: Ktelang
    Ok i did that.
    Now i can find my macro in macros category...
    And now what???
    Active Contributor
    nikhunter
    11-30-2012 04:11 PM in reply to: Ktelang
    Ok Mike i think i done it....I will try a liitle bit by myself because i feel that i tired you, and if i have another question i will be back.....
    I realy thank you and appriciate all your help.....
    Employee
    11-30-2012 04:15 PM in reply to: nikhunter
    OK, great. I forgot one thing: you should set an option so that the VBA macros are available all the time.
    Under Application Options
    Check the Load VBA on start-up  option
    Mike Deck
    Software Developer
    Autodesk, Inc.
    Active Contributor
    nikhunter
    11-30-2012 04:28 PM in reply to: Ktelang
    Hmmmm.Mike  i have autodesk 2011 and i dont have any of this setting...Look at Yourself
    Active Contributor
    nikhunter
    11-30-2012 04:36 PM in reply to: Ktelang
    Finally i enter a shortcut Key on a macro as you say...
    But how it can be activated???I mean when i can press the button "A" for example, and run my macro???
    I must do somethimg else???It's about this setting you send me???
    Employee
    11-30-2012 04:43 PM in reply to: nikhunter
    You don't need the Load VBA on start-up option in Inventor 2011.  But it is required in Inventor 2013 (and maybe 2012).
    If your macro is not working, I don't know what the problem might be. I would recommend using two letters instead of one for your shortcut. Please send me a screenshot similar to the one below:
    Mike Deck
    Software Developer
    Autodesk, Inc.
