• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    ilogic idw dimension problem
    274 Views, 5 Replies
    10-16-2012 01:45 PM
    I have a tube and with ilogic I have different amounts of holes depending on how long the tube.
    How can make it so that it always dimensions the holes properly.
    It will dimension some holes twice and some holes it doesn't dimension at all.
    Please use plain text.
    Product Support
    innovatenate
    Re: ilogic idw dimension problem
    10-19-2012 09:58 AM in reply to: lester
    Lester,
    Can you upload a sample file to investigate?
    Nathan Chandler
    Product Support Specialist
    Product Support Americas
    mrattray
    10-19-2012 10:12 AM in reply to: lester
    How are you applying the dimensions?
    Mike (not Matt) Rattray
    Valued Contributor
    10-19-2012 10:44 AM in reply to: innovatenate
    Here it is.
    Product Support
    innovatenate
    10-25-2012 03:59 PM in reply to: lester
    Without going into VBA and the API, I don't believe there's a way to do this. You may find better assistance with that in the customization forum. My thought is that the ordinate dimensions would need to be deleted and recreated any time the drawing view is updated to prevent the 'sick' dimensions.
    Rather than putting ordinate dimensions on the drawing view (and dealing with custom code), have you considered using a hole table? I believe that the hole table will remain associative with the view.
    Another thought is to create an iAssembly (warning: iLogic will not persist in iAssembly member files). A single view of the  iAssembly may be created, with a generic table associated to it. Something like this:
    Nathan Chandler
    mrattray
    10-26-2012 04:44 AM in reply to: lester
    I agree with Nathan, Lester.
    Although it is possible to do this with the API, it is very complicated. Here is a thread where the OP has written code to insert and detail a part: http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-Coding-to-Create-Automated-Draw...
