Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ilogic form dropdown?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you have dropdowns in an ilogic FORM?
For example I want to setup 5 choices for a custom iproperty. Then when I run the form I can pick from those 5 choices only?
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
Re: ilogic form dropdown?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The way I have done it in the past is with a Custom Parameter that is Exported to be a Custom iProperty. I use the Multi-value list from the parameter to drive the value of the Custom iProperty
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yep you sure can Here is my form I am working on now.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
How did make columns in your form?
Reg
Autodesk Product Design Suite Premium 2014 Build 170
Intel Core i7 (950@3.07GHz)
Windows 7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Mark, how do you export a multi-value text parameter?
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually I misspoke, I use an ilogic rule to copy the value of the MultiValue parameter to the value of the custom iproperty. There is no export on the MultiValue parameters.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Would you mind sharing this code?
Stew, AICP
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi everyone,
You can use MultiValue.SetList to add values and convert a parameter to a multi-value parameter.
Here's a quick example.
There is a sketch dimension / parameter called Length.
There is a rule with this line of code.
MultiValue.SetList("Length", 100, 150, 200, 250)
There is a form set up like this:
Attached is the example file (Inventor 2013)
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi mcgyvr,
You could also add a few lines to expose (export) the parameter value as a property. So using the previous example you set the Length using a form, and this code sets the list and ensures the parameter is exported as a custom iProperty.
'set list of values
Dim oLength As Parameter
oLength = Parameter.Param("Length")
oLength.ExposedAsProperty = True
But if you need the parameter value to be written to a custom iProperty that is not the same name as the parameter you could use something like this. In this example a custom iProperty called L1 is created or reused, depending if it exists. And the Length parameter value is written to it:
'set list of values
Dim propertyName1 As String = "L1"
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
'set property value
oProp = oCustomPropertySet.Item(propertyName1)
Catch
' Assume error means not found so create it
oCustomPropertySet.Add("", propertyName1)
End Try
'set custom property value
iProperties.Value("Custom", "L1") = Length
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
iproperty NOT parameter
I just want a form with a drop down to fill in the value of a custom iproperty.
Currently I'm doing it with an "Input Box" rule which is fine but not as pretty as I could make a form.
Seems totally silly to me this isn't build into ilogic forms already..
It should be as simple as this.. See attached
Windows 7 64 bit
