• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Re: ilogic and work plane visibility
    09-24-2012 12:18 PM in reply to: david.campbell
    Your sample #3 seams to produce the same results I am having with the code I am currently using.
    I am going to use your sample #3 for further discussions so that we are on the same page.
    Thanks again
    Inventor 2013
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    09-24-2012 12:49 PM in reply to: david.campbell
    Hi Diswill,
    I think what you're seeing is an issue with view reps in the sub assembly.  Basically, we'll need to have a few lines of code check the component to see if it's an assembly file, and then use or create a view rep in the sub assembly.
    To test this theory you can create a view rep in your sub assembly and ensure that your sub assembly is placed using that view rep, and then I think you'll see that the rule works as expected.
    I'll post back if I have time to look into the needed code update later.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Member
    09-24-2012 01:17 PM in reply to: Curtis_Waguespack
    your assumption about the view representation appears to be correct.
    for us assemblies are normally places with the master view representation.
    Your assistance is greatly appreciated.
    Inventor 2013
    *Expert Elite*
    Curtis_Waguespack
    09-24-2012 01:46 PM in reply to: david.campbell
    Hi Diswill,
    Let's back up a step or two.
    Are you wanting to use iLogic to :
    A) turn off the visibility of work planes at the top level assembly?
    B) reach down into each component and turn off the visibility of the work planes
    If A, then I think this one line will do the trick:
    ThisApplication.CommandManager.ControlDefinitions.Item("AppAllWorkfeaturesCmd").Execute
     This is the same as going to the VIew tab > Object Visibility button > All Work Features check box.
    But if you're needing B, then we were on the right track earlier, and we'll need to add some lines to look at the sub assembly view reps.
    I hope this helps.
    Curtis
    Active Member
    09-24-2012 02:09 PM in reply to: Curtis_Waguespack
    We are looking at option B
    Using the Object Visibility under the view tab is not what we want.
    We want clean assemblies with no plane visibility being active on any part or assembly / subassembly at any level as a starting point for the next group to start working with.
    The group work in works mainly with planes and it becomes a pain to go to each part and turn off each plane then move to each subassembly and turn off each plane. Then so on up to the main assembly.
    When the next group grabs our main assemblies in uses them in the larger project a few planes being left on by accident becomes a problem.
    Inventor 2013
    *Expert Elite*
    Curtis_Waguespack
    09-24-2012 03:30 PM in reply to: david.campbell
    Hi Diswill,
    I think this will do it. I didn't have much time to review this, so you might find some un-needed lines, etc.
    I'm probably missing something obvious, but as is this example only looks at sub assemblies one level deep. Meaning that if you have an assembly in your subassembly, it won't turn off the workplanes for the same reasons as before (view reps).
    If I think of something different, I'll post back.
    I hope this helps.
    Curtis
    sample #4
    'get user input
    oInput = InputRadioBox("Select workplane visibility:", _
     "Turn ON workplanes for all components", "Turn OFF workplanes for all components", "False", "iLogic")
    ' set a reference to the assembly component definintion.
    Dim oAsmCompDef As AssemblyComponentDefinition
    oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    'Define the open document (top level assembly)
    Dim openDoc As Document
    openDoc = ThisDoc.Document
    'define view rep
    Dim oViewRep As DesignViewRepresentation
    Dim sVRep as String
    'change to something else if Default is used for something already
    sVRep = "Default"
    'create or activate view rep in the top level assembly
    Try
    oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
    Catch
    'create new View Rep
    oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
    End Try
    'create or activate view rep in subassemblies
    Dim docFile As Document
    For Each docFile In openDoc.AllReferencedDocuments
    Dim subDoc As AssemblyComponentDefinition
    If docFile.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
    subDoc = docFile.ComponentDefinition
    Try
    subDoc.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
    Catch
    subDoc.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
    End Try
    Else
    End If
    Next
    'toggle work planes in the open document (top level assembly)
    For Each oWorkPlane In openDoc.ComponentDefinition.WorkPlanes
    'toggle all work planes
    If oInput = True Then
    oWorkPlane.Visible = True
    ElseIf oInput = False Then
    oWorkPlane.Visible = False
    End If
    Next
    'look at only the subassemblies
    Dim subDocFile As Document
    For each oCompOcc in oAsmCompDef.Occurrences
    If oCompOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
    oCompOcc.SetDesignViewRepresentation(sVRep,, True) 'True sets the view rep to be associative
    Else
    End If
    Next
    'Look at all of the files referenced in the open document
    'format  file name
    Dim FNamePos As Long
    FNamePos = InStrRev(docFile.FullFileName, "\", -1)
    Dim docFName As String
    docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
    For Each oWorkPlane In docFile.ComponentDefinition.WorkPlanes
    End If
    Next
    Next
    iLogicVb.UpdateWhenDone = True
    Active Member
    09-25-2012 05:47 AM in reply to: Curtis_Waguespack
    This sample seams to catch most of our problems.
    Yes we can bury assemblies several layers deep but not so deep that it will require to add to this code.
    I really appreciate you and your help.
    Thanks again.
    Inventor 2013
    01-15-2013 08:36 AM in reply to: Curtis_Waguespack
    This is exactly what I was looking for.
    Would it be too much to ask to supplement the code to also turn off the work axes and work points? Basically I want all the work features to turn off.
    Thank you!
    *Expert Elite*
    Curtis_Waguespack
    01-15-2013 11:11 AM in reply to: pistonrod8
    Hi  pistonrod8,
    Here is a modified version that handles all work features.
    I hope this helps.
    Curtis
    'get user input
    oInput = InputRadioBox("Select work feature visibility:", _
     "Turn ON work features for all components", _
     "Turn OFF work features for all components", "False", "iLogic")
    'define view rep
    Dim sVRep as String
    sVRep = "Default"
    Try
    Catch
    End Try
    Try
    Catch
    End Try
    Else
    End If
    Next
        'toggle work features in the open document (top level assembly)
        End If
        Next
        For Each oWorkAxis In openDoc.ComponentDefinition.WorkAxes
        oWorkAxis.Visible = True
        oWorkAxis.Visible = False
        End If
        Next
        For Each oWorkPoint In openDoc.ComponentDefinition.WorkPoints
        oWorkPoint.Visible = True
        oWorkPoint.Visible = False
        End If
        Next
    Else
    End If
    Next
        'toggle work features in the components
        End If
        Next
        For Each oWorkAxis In docFile.ComponentDefinition.WorkAxes
        End If
        Next
        For Each oWorkPoint In docFile.ComponentDefinition.WorkPoints
        End If
        Next
    Next
    01-15-2013 11:23 AM in reply to: Curtis_Waguespack
    That works great. Thank you!
