• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    brian
    Accepted Solution
    ilogic - Adding User Parameters with Custom Properties Format
    894 Views, 10 Replies
    05-21-2012 04:59 AM
    I would like to have a rule that will add specific user parameters to a part file.  These parameters need to be formatted so the width, depth and thickness will control the description of the part.
    IE:
    Width=4
    Depth=2
    Thickness=3/16
    DESCRIPTION = TS <Width>X<Depth>X<Thickness>
    I would like to format each parameter so that the:
    Format=Fractional
    Precision=1/16
    Unit string=False
    This is what I have so far:
     oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
    oParameter=oMyParameter.AddByExpression("Width", "TOP_RAIL_WIDTH", UnitsTypeEnum.kInchLengthUnits)
    oParameter.ExposedAsProperty=True
    oParameter.Units="in"
    oParameter=oMyParameter.AddByExpression("Depth", "TOP_RAIL_DEPTH", UnitsTypeEnum.kInchLengthUnits)
    oParameter=oMyParameter.AddByExpression("Thickness", "TOP_RAIL_THICKNESS", UnitsTypeEnum.kInchLengthUnits)
    The TOP_RAIL parameters are from a linked file.
    Brian
    Please use plain text.
    *Pro
    jletcher
    Re: ilogic - Adding User Parameters with Custom Properties Format
    05-21-2012 06:26 AM in reply to: brian
    just put a check in the export box in the parameters. for the format after you put a check mark in the export box if you go over to the equation right click you wil have new options. One is custom property format in there you can change the output.....
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    *Pro
    jletcher
    05-21-2012 06:27 AM in reply to: jletcher
    Oh and you don't really need ilogic..
    James Letcher
    *Expert Elite*
    Curtis_Waguespack
    05-21-2012 08:20 AM in reply to: brian
    Hi brian
    Here is some iLogic code and an example file that will format parameters and add them to the Description iProperty.
    I hope this helps.
    Curtis
    Dim oWidth, oDepth, oThickness  As Parameter
    Dim oFormat As CustomPropertyFormat
    oWidth = Parameter.Param("Width")
    oWidth.ExposedAsProperty = True
    oFormat=oWidth.CustomPropertyFormat
    oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
    oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
    oFormat.Units="in"
    oFormat.ShowUnitsString=False
    oDepth = Parameter.Param("Depth")
    oDepth.ExposedAsProperty = True
    oFormat=oDepth.CustomPropertyFormat
    oFormat.Units="in"
    oThickness = Parameter.Param("Thickness")
    oThickness.ExposedAsProperty = True
    oFormat=oThickness.CustomPropertyFormat
    oFormat.Units="in"
    iProperties.Value("Project", "Description") = "= TS <Width> x <Depth> x <Thickness>"
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Member
    brian
    05-21-2012 08:44 AM in reply to: Curtis_Waguespack
    Curtis,
    It works great.
    Brian
    *Expert Elite*
    Curtis_Waguespack
    05-21-2012 09:20 AM in reply to: brian
    Hi brian,
    I'm glad to hear that worked.
    I noticed that I left those first two lines of the code in. They're not really needed, and don't really do anything as written because  those things get defined later in the code. They were just vestiges of my first attempt that I forgot to remove once I went a different way.  I just thought I'd mention it in case it confuses someone who happens upon this in the future.
    I hope this helps.
    Curtis
    so, this works just as well:
    oFormat.Units="in"
    oFormat.Units="in"
    oFormat.Units="in"
    New Member
    12-05-2012 09:13 AM in reply to: brian
    sir can anyone help me to update the thickness of a sheet metal,  through custom properties in BOM(Assembly level)
    if i create opposite hand of a part the thickness will not getting updated please help me out update through custom properties, i want like if i update the custom properties thickness then automatically it has to get updated in parameters.
    thanks and regards
    Manjunatha
    Active Member
    12-20-2012 11:20 PM in reply to: Curtis_Waguespack
    sir, can you help me create co to remove All Custom property?
    i want to clearup all custom properties and add new one.
    Thanks and regard
    New Member
    01-15-2013 06:07 PM in reply to: akhidrosyidi
    Remove directly from iproperties.
    New Member
    01-19-2013 05:27 PM in reply to: manjunathmvbhat
    Create the opposite hand using derived component. Derive a mirror part and bring the parameters of the original. This way both thicknesses will get updated.
