• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    gordon.rogers
    idw parts list does not match BOM
    181 Views, 5 Replies
    03-18-2013 10:15 AM
    I made an assembly about 1-1/2 months ago and had no issues with parts list and BOM matching. Now as you can see from the attached file they don't match. Any help and suggestions will be appricated.
    IV2013
    Please use plain text.
    *Expert Elite*
    jtylerbc
    Re: idw parts list does not match BOM
    03-18-2013 01:01 PM in reply to: gordon.rogers
    Have the quantities been overridden in the parts list?
    Open the parts list for editing, check to see if those quantities appear in blue text with a blue cell outline.  This indicates that the cell's value has been overridden.
    If that is is the case, right click on the cells and uncheck "Static Value".  This will remove the override and the parts list should match the BOM.
    John Tyler
    Inventor 2013
    Windows 7 64 Bit
    gordon.rogers
    03-18-2013 02:12 PM in reply to: jtylerbc
    No the qty's are not overiden. Also as you can see the SAP Material numbers are not correct either. I'm gonna make a new sub-assembly and replace it to see if that works. Its really frustrating when I put the current sub assembly in its own drawing and the parts list and BOM match. I even put the whole assemble in a new idw and same results, parst list doesn't match BOM.
    *Expert Elite*
    ScottMoyse
    03-18-2013 06:22 PM in reply to: gordon.rogers
    I see the parts in the BOM are greyed out which means they are Read Only. Are you using Vault?
    Have you tried a Rebuild All on the parent assembly?
    Are they any Representations or LOD's active in the parent assembly or BOM overrides (reference etc)?
    If Quantity really was 0 it shouldn't even appear in the parts list.
    I'd say there is something up with the parent assembly & not the parts list. Have you checked the Quantity Units on those components?
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    gordon.rogers
    03-19-2013 07:34 AM in reply to: ScottMoyse
    Yes we are using Vault. LOD is set to master. I've changed the sub-assembly from normal to phatom and the part numbers and qty's work but lose the numbering scheem. I'm beginning to think the file might have gotten corrupted when we upgraded from 2012 to 2013. Thought someone might have run across this. I'm just gonna make new sub and replace.
    Employee
    03-19-2013 04:00 PM in reply to: gordon.rogers
    Hi! The behavior you described here does not seem right to me. If you could send me the files, I would take a look and see where the problem is. For dataset smaller than 20MB, please send it via email (johnson.shiue@autodesk.com). For larger dataset, please send me an email so I can set up a secure account for you to upload.
    BTW, LOD should not interfere with BOM. If you have an example showing LOD changes BOM, please let me know asap.
    Thanks!
    Principal SQA Engineer, Inventor
    Manufacturing Group
    Autodesk, Inc.
