• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Accepted Solution
    idw paper colour
    194 Views, 7 Replies
    01-15-2013 01:51 AM
    i have an idw with a black drawing background, i want to change this to a different colour but cant seem to find where to do this, could someone point me in the right direction to do this.
    Please use plain text.
    Valued Contributor
    machiel.veldkamp
    can you..
    01-15-2013 01:52 AM in reply to: egghead
    Can you post a screencap of this?
    ___________________________
    Inventor 2012 lastest service pack
    RAM: 16GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
    Video: NVidia Quardo 2000 / HDD: 15.7K
    Windows 7 Pro 64-bit
    Re: idw paper colour
    01-15-2013 01:58 AM in reply to: egghead
    Attached is a screen shot of what i mean, i want to change the black area to a different colour.
    *Expert Elite*
    sam_m
    01-15-2013 02:00 AM in reply to: egghead
    To change the sheet colour:
    "Tools" ribbon -> "Document Settings" -> "Sheet" Tab -> "Sheet" button
    *edit*
    just realized you might have some fun with this...
    If you have a black sheet then I'm guessing all your styles are in something like white or yellow (ie a light colour) to be visible against the black.  If you change the sheet to a white/beige then you may well be drawing white on beige, which might not be massively helpful.  May have to go into Styles Editor to change all your layers to something dark("Manage" ribbon -> "Styles Editor" -> "Layers" and then click one to display the colour tabs)...
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
    01-15-2013 02:28 AM in reply to: egghead
    just what i was looking for great.
    *Expert Elite*
    sam_m
    01-15-2013 02:52 AM in reply to: egghead
    does that mean it's a solution? :smileywink:
    01-15-2013 03:06 AM in reply to: egghead
    yes worked a treat just what i was after, i know what you mean about the text etc on the background.
    i only wanted to change it while i made some changes to the border and then i will be changing it back to the original colour.
    many thanks for your help with this matter.
    *Expert Elite*
    sam_m
    01-15-2013 04:05 AM in reply to: egghead
    I was more suggesting to mark the reply as an approved solution, if you find it to be one :smileyembarrassed:
    It adds the green tick to the title so if anyone in the future with a similar problem searches the forum, they can tell just from the title that there is a possible solution inside (without needing to open and read every search result).
