• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Trull, Michael
    Re: iParts - Did you know?
    11-13-2003 12:13 AM in reply to: *Iwaskewycz, Brian R.
    How do you get the spreadsheet function to update when inserting a custom
    iPart?
    By way of explanation, I use custom iParts for standard materials such as
    strut channel and 2X2 steel tube where you enter the length when you insert
    the iPart. I then edit the part numbers for these parts to include the
    length using iProperties. Since I would like to avoid having to edit the
    part number each time I create a new part, spreadsheet functions seemed to
    be an ideal solution.
    So I set up a table for an iPart factory using Excel's text functions
    (concatenate and some others) to create the correct part number, but when I
    insert a custom iPart with this factory they always have the length as 36 in
    the part number (36 is the default length of the iPart factory) rather than
    the actual length of the custom iPart. And if I change the length, the part
    number does not update. Either the function is not running when the custom
    iPart is created or the part number function is not referencing the custom
    length.
    Any suggestions on how I can get this to work?
    Sincerely,
    Michael
    Please use plain text.
    *Stubbington, Scott
    Re:
    11-13-2003 05:40 PM in reply to: *Iwaskewycz, Brian R.
    There are two places you can store VBA routines in Excel aren't there, one
    being the workbook and the other being your personal.xls workbook... correct
    me if I'm wrong. In the situation where VBA routines were corrupting the
    IPart sheet, was the VBA routine stored in the workbook or the personal
    workbook?
    Just curious
    Scott
    *Keller, Kent
    Re:
    11-14-2003 12:31 AM in reply to: *Iwaskewycz, Brian R.
    Hi Scott
    It has been a while, but as I remember it was in the "ThisWorkbook" that I placed the
    code.
    Kent
    Assistant Moderator
    Autodesk Discussion Forum Moderator Program
    "Scott Stubbington" wrote in message
    > workbook?
    > Just curious
    > Scott
    Re:
    11-16-2003 09:48 PM in reply to: *Iwaskewycz, Brian R.
    You could create any sort of function you want to generate the filename, but
    it's not going to work with a custom iPart. As soon as you define a column
    as a custom column (or a single cell as someone (Sean?) found), Inventor
    ignores whatever is in the Filename column, and the user must manually
    specify the filename and path.
