Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*A., Kirk
iPart problem
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
39 Views, 5 Replies
12-12-2002 10:29 PM
My SHCS iPart (that I got from cbliss.com) is giving me a fit. If I do a
"replace component", I will loose any constraint that was on the original
part. This only happens on one size, 1/2-13x1. All the other sizes will
replace and not loose the constraint.
The error that I get tells me that Inventor thinks that the part is
different
I have tried this:
1. Deleted the child part from the iPart directory and opened a blank
assembly drawing and inserted the problem size.... thus rebuilding this one
size. Did not fix the problem.
2. I also tried renaming the parent file and creating several child parts,
then inserting and constraining the parts. I can do a "replace component"
and not loose any constraints. Works great.
Any ideas on what I can do so this one bolt will work properly??
Inventor 5.3 sp2
Win XP Pro
P4, 2 Ghz, 512M
Gloria II-64
nVidia v6.13.10.4041
1280x1024, 32 Bit
different
I have tried this:
Inventor 5.3 sp2
Win XP Pro
P4, 2 Ghz, 512M
Gloria II-64
1280x1024, 32 Bit
*Maas, Karl
Re: iPart problem
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-12-2002 11:34 PM in reply to:
*A., Kirk
I inserted it using the default 1/4-20 x 1". I lost my constraint everytime
I changed from/to this size. But changing between all the other sizes went
well.
K
"Kirk A." wrote in message
news:C125BCC333BF8DA44ED42B22A6530882@in.WebX.maYI adrTaRb...
> different
> I have tried this:
one
> Inventor 5.3 sp2
> Win XP Pro
> P4, 2 Ghz, 512M
> Gloria II-64
> 1280x1024, 32 Bit
well.
K
"Kirk A."
> different
> I have tried this:
one
> Inventor 5.3 sp2
> Win XP Pro
> P4, 2 Ghz, 512M
> Gloria II-64
> 1280x1024, 32 Bit
*A., Kirk
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-13-2002 12:02 AM in reply to:
*A., Kirk
Karl,
Good to see that I am not the only one with this problem.
Anyone know why this happens?
Kirk
"Karl Maas" wrote in message
news:448BF4AF7AA7D50F3FF44D4C33A813B3@in.WebX.maYI adrTaRb...
everytime
> well.
> K
a
original
will
> > different
> > I have tried this:
> one
parts,
component"
> > Inventor 5.3 sp2
> > Win XP Pro
> > P4, 2 Ghz, 512M
> > Gloria II-64
> > 1280x1024, 32 Bit
Kirk
"Karl Maas"
everytime
> well.
> K
> "Kirk A."
a
original
will
> > different
> > I have tried this:
> one
parts,
component"
> > Inventor 5.3 sp2
> > Win XP Pro
> > P4, 2 Ghz, 512M
> > Gloria II-64
> > 1280x1024, 32 Bit
*Gwin, Hal
Re: iPart problem
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-13-2002 01:05 AM in reply to:
*A., Kirk
If I remember correctly when I used that part I also ran across that error.
I edited the part and found an issue with the head at 1/4" and larger sizes.
That was what was causing the loss of constraint at the larger sizes. I
thought I had sent Charles an updated copy of the part. I may have
forgotten to.
Hal Gwin
Mechanical Designer
Xenogen
forgotten to.
Hal Gwin
Mechanical Designer
Xenogen
*A., Kirk
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-16-2002 11:15 PM in reply to:
*A., Kirk
Hal,
When I downloaded the files, I found that the head diameter and the body
diameter was not concentric. I fixed this about a year ago on all my bolts.
When I started having this problem, I relooked at the model. There was not
anything that stood out as being the culprit.
Can you tell me what you found so that I could make the change to my models.
Kirk
"Hal Gwin" wrote in message
news:4064962D20B9DBBFB5575A044E4D7486@in.WebX.maYI adrTaRb...
error.
sizes.
> forgotten to.
> Hal Gwin
> Mechanical Designer
> Xenogen
Kirk
"Hal Gwin"
error.
sizes.
> forgotten to.
> Hal Gwin
> Mechanical Designer
> Xenogen
*Gwin, Hal
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2002 12:52 AM in reply to:
*A., Kirk
That was what I found and fixed as well. I haven't had any problems since
then. I just opened an assembly, dropped several instances into it, and
changed to several sizes and lengths. Everything works fine.
Wish I could be of more help.
Hal Gwin
Mechanical Designer
Xenogen
Hal Gwin
Mechanical Designer
Xenogen
