• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    iPart Problems (without file)
    18 Views, 1 Replies
    11-14-2002 02:10 AM
    I know very little about this, but I think the key word is 'Library'. There are several threads in the NG about, libraries being changed to read-only in IV6; maybe this is the problem.
    Please use plain text.
    *Brown, Anne
    11-14-2002 02:55 AM in reply to: tbrack
    Chris -
    Three users reported that the files crashed their newsgroup
    reader so the files were removed. Files should not be posted to
    technical support groups. Below is the standard text sent on
    files. Please ZIP your files and repost to Customer Files.
    Customer Files area ay be found at
    (news://discussion.autodesk.com/autodesk.autocad.customer-files
    or http://discussion.autodesk.com/WebX?14@@.ee940b5). Please do
    not post files or graphics in product support groups and zip
    files (if possible) to take up less space and download time.
    See the newsgroup guidelines at
    http://discussion.autodesk.com/webx?groundrules.
    Anne Brown
    Manager, Moderator
    Autodesk Product Support discussion groups
    Discussion Q&A: http://www.autodesk.com/discussion
    Subject:
    iPart Problems
    Date:
    Thu, 14 Nov 2002 08:56:44 -0800
    "Chris Ludtke"
    Organization:
    Ball Aerospace and Technologies
    Newsgroups:
    autodesk.inventor.6
    I have a well thought out, perfectly healthy iPart factory in
    5.3.
    When I bring it into 6 I am unable to edit the table. I get a
    message
    telling me that the current values do not match the parts current
    values.
    It then asks me if I want to update the table befor continuing.
    I assume that if I choose "Yes" the value of the table is
    supposed to update to match the current current value.
    I also assume that if I choose "No" the value of the table will
    not update.
    Here is the kicker, whether I choose yes or no, upon exiting the
    iPart
    Author dialog box that says "Cannot modify the library file C:\
    factory.ipt"
    I am significantly troubled by this. We have invested a
    significant amount
    of money in iParts that worked great in 5.3. We are wondering if
    we are
    losing that investment. I have tried searching for errors in 5.3
    and have
    found nothing. I can get no clues from 6.0. Anyone out there
    have a
    solution?
    I have attached the ipart of a simple screw (307 different
    separate line
    items). We have many more of these, this is a small one. Please
    help me.
    Note that I have attached our companies "Threads.xls" file. The
    iParts will
    not work in 5.3 without this file.
    (These files were removed as there were reports that they crashed
    OE newsgroup readers - Moderator)
    Attachments: test.ipt
    Thread.xls
