• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    xmer
    iPart Issue
    119 Views, 1 Replies
    03-05-2012 05:18 AM
    Hi all,
    I'll be really thanksful, if somebody can give some direct solution.
    Here we go.. I have an iPart with 10 Variation. Actually it is an assembly. but for the purpose of convinience I made it into iPart. I know the physical weight of all 10 variation.
    When i create this iPart, the variation weight don't match with actual. so I want to incorporate the already determined weight for each variation. therefore I can get the same, when i use it in BOM.
    iPart excel, is not giving option to add mass property.  It can be done by changing density. but I want to keep the same density.
    Is there any other possibilities..???
    Thanks in advance..
    Please use plain text.
    *Expert Elite*
    Re: iPart Issue
    03-05-2012 01:33 PM in reply to: xmer
    The thread linked below deals with the same question.  You may find some answers there.
    http://forums.autodesk.com/t5/Autodesk-Inventor/Adding-Mass-Overides-to-Iparts/m-p/3271247#M421537
