• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Maenpaa, Mike
    Re:
    12-08-2002 11:16 PM in reply to: *Keller, Kent
    Karl,
    No. Assembly features don't modify the actual .ipt file. During part design,
    I would like to be able to pick a PEM nut,stud,etc. and have the appropriate
    hole placed on the .ipt file, plus since this PEM has to be added in the
    assy, add the insert constraint at the same time.
    Mike
    "Karl Maas" wrote in message
    news:3AA0815C9C596977FA402A6FB9711748@in.WebX.maYIadrTaRb...
    > shouldn't that be an assembly feature?
    > K
    > "Mike Maenpaa" wrote in message
    > news:9745080A4D9E8FC96D0AC3D5B35D5524@in.WebX.maYIadrTaRb...
    > > Yup!
    > > Or even better, if you could select your screw, bolt, or PEM and the
    > correct
    > > hole size is placed on your part.
    > > Mike
    > > "Kent Keller" wrote in message
    > > news:51ED34CC4E8B15B4D8385AEE9AC1ABC0@in.WebX.maYIadrTaRb...
    > > > Wouldn't it be cool if there was a hole tool like what Ryan and Drew
    > made,
    > > built into
    > > > Inventor, and it also automatically added a named imate when you made
    > the
    > > hole. Then in
    > > > assembly mode you would just have to insert your iParts with pre setup
    > > imate names that
    > > > matched and everything would fall together.
    > > > Kent
    > > > Member of the Autodesk Discussion Forum Moderator Program
    Please use plain text.
