Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: iLogic workflow for suppressin g / excluding components
- Highlight
- Email to a Friend
Is "TR" a parameter in the same assembly as the iLogic rule? Typically the parameters will display as the color blue.
As a test, insert the line of code
msgbox(TR)
and see what value the program thinks TR is.
If TR is in a part or assembly other than where you are referencing it then you access it differently. If this is the case look into:
Parameter("Part1:1", TR) = 1
or
Parameter(MakePath("SubAssem1:1", "Part1:1"), TR) = 1
-Shawn
- Highlight
- Email to a Friend
Thanks for your reply Shawn_79 ![]()
I know for the blue color now ![]()
the Multivalue text parameter is not linkable???
- Highlight
- Email to a Friend
I do not use many multi value parameters, but I would not expect them to work differently from any other parameter.
Did msgbox(TR) return the an expected value? If it returns blank then you may not be referencing the parameter "TR" correctly in your code. Did you type "TR" or access it by double click from the parameter table in the top left of the iLogic editor?
- Highlight
- Email to a Friend
all work great now, suppress all i want, but my biggest problem is all my text parameter is not linkable???
all my parameter is in my frame sketch but i see only a numeric parameter, all text parameter is not here???
Thanks again Shawn_79 ![]()
- Highlight
- Email to a Friend
Check out "Parameters Functions" for the iLogic help. It will explain the various ways to access the parameters.
I have several text type parameters I access by code. As an example I use Parameter("SKEL", "CoolingType") to reference CoolingType parameter in my skeleton part from an upper assembly.
-Shawn
