• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    Curtis_Waguespack
    iLogic set Design View Representation by material
    601 Views, 0 Replies
    12-22-2011 12:50 PM
    This topic is in response to another thread:
    http://forums.autodesk.com/t5/Autodesk-Inventor/ilogic-or-vb-help/m-p/3268448
    I figured I'd start an new topic with the subject line that might come up in future searches in case it helps someone at some point.
    Here's an ilogic rule to handle the view reps. I didn't test it all that thoughly, so I can't promise you won't find an error. Also note that it looks for a view rep of the same name it is trying to create, and deletes it if found. I think there is a better way to handle this, but I didn't find the time to work on this any further.
    I hope this helps.
    Curtis
    'define the Material being looked at
    Dim oMatl as Object
    oMatl = "Steel"
    'define View Rep name
    Dim oNotMatl as Object
    oNotMatl = "No " & oMatl
    ' set a reference to the assembly component definintion.
    ' This assumes an assembly document is open.
    Dim oAsmCompDef As AssemblyComponentDefinition
    oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim oViewRep As DesignViewRepresentation
    'Look for an existing View Rep of the same name and delete it if found
    For Each oViewRep in oAsmCompDef.RepresentationsManager.DesignViewRepresentations
    	If oViewRep.Name = "Master"  Then
    	'set the Master View Rep to be active
    	oViewRep.Activate
    	'if Master is already active, skip error
    	On error Resume Next
    	'look for same name view rep
    	Else if oViewRep.Name = oNotMatl  Then
    	'delete same name view rep if found
    	oViewRep.Delete
    	Else
    	End if
    Next
    'create new View Rep
    oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(oNotMatl)
    'define current document
    Dim openDoc As Document
    openDoc = ThisDoc.Document
    'kAssemblyDocumentObject = 12291
    If openDoc.DocumentType = 12291 Then
    	'look at all of the components in the assembly
    	Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition
    	'define the first level components collection
    	Dim oCompOcc As Inventor.ComponentOccurrence
    	'define the next level components collection
    	Dim oSubCompOcc As Inventor.ComponentOccurrence
    	'Turn off the visibility of parts in the top level assembly that are the specified mat'l
    	For each oCompOcc in oCompDef.Occurrences
    		If iProperties.Material (oCompOcc.Name) = oMatl Then
    		'Turn the visibility off
    		oCompOcc.Visible = False
    		End If
    		'Turn off the visibility of parts in the second level assemblies that are the specified mat'l
    	    	For Each oSubCompOcc In oCompOcc.SubOccurrences
    	        		'select for part files with specified material
    			If iProperties.Material (oSubCompOcc.Name) = oMatl  Then
    			oSubCompOcc.Visible = False
    			End If
    	    	Next
    	Next
    Else
    	MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!")
    End If
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Please use plain text.
