Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
iLogic help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So I'm having an issue with suppressing components when the conditions vary. I have some wedges and the the configuration and quantity varys based on the parameter selected. I can have one wedge per pocket, two wedges per pocket, and so on. The pockets also vary. There may be 2, 3, 4, or 5 pockets with either 1, 2, or 4 wedges each. I'm not sure the best way to suppress them when the conditions change. I currently have enough wedges for each variaton, but when parameters change some seem to stay active. Any suggestions. I may not have this set up the best way, or I may just need a bunch more rules, but I'll take any suggestions! Files are attached.
Re: iLogic help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What version of inventor are you using?
Re: iLogic help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: iLogic help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think there may be a much neater solution - but you'll need to post all the files for someone to have a look. The 3 files you have attached don't make up the whole assembly.
From the little I can see, you would be better off creating an assembly pattern of stakes and wedges, then controlling the number in the pattern through your iLogic rules.
I could be wrong - I just can't see the whole model.
Re: iLogic help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
^^^ Agreed.
Post files, and despite that I can not use them (2012), if you also post pictures (and even code!) I'm sure we can all figure out a better way to do it than massive sheets of ilogic.
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
