• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    iLogic commands!
    405 Views, 8 Replies
    01-16-2013 08:15 AM
    Hi all!
    I`m starting to learn about iLogic, and have a couple of questions regarding this matter.
    I`m using adaptive planes and the split command to cut the pipes to each other. After the cut plane is constrained I want the plane to be turned off automatically.
    To achieve this I`v tried using a if command, without luck obviously.
    IfConstraint.IsActive("all the parts to look in", "Work plane 3") Then
    Feature.IsActive("that specific part", "Work plane 3")=False
    Else
    Feature
    .IsActive("that specific part" , "Work plane 3")=True
    EndIf
    Is this possible?
    Kind regards
    Please use plain text.
    Re: iLogic commands!
    01-17-2013 05:49 AM in reply to: 128848
    Anyone?
    Valued Contributor
    01-17-2013 06:55 AM in reply to: 128848
    I have just attempted to solve your problem but I can't seem to find a command which will turn the Visability of a Work Plane off.
    You need something similar to
    If Constraint.IsActive("Mate:1")=True Then
    WorkPlane.Visible("Work Plane1")=False
    Else
    WorkPlane.Visible("Work Plane1")=True
    EndIf
    but there is no such comand as 'WorkPlane.Visible' or 'WorkPlane.IsActive'
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    *Expert Elite*
    Curtis_Waguespack
    01-17-2013 07:20 AM in reply to: 128848
    Hi 128848,
    This link has several examples of iLogic to handle workplanes:
    http://forums.autodesk.com/t5/Autodesk-Inventor/ilogic-and-work-plane-visibility/m-p/3383929#M429508
    Keep in mind you might search and ask questions of this type on the Inventor Customization forum:
    http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    01-24-2013 09:11 AM in reply to: Curtis_Waguespack
    Have been trying out some codes, without luck.
    'define document
    Dim oDoc As PartDocument
    oDoc = ThisDoc.Document
    'look at the workplane collection
    For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
    If oWorkPlane.Constraint.IsActive("Mate:1")=True Then
    oWorkPlane.Visible =False
    ElseIf oWorkPlane.Visible=False Then
    oWorkPlane.Visible=True
    EndIf
    Next
    Here`s the message I get.
    Error in rule: Rule0, in document: Assembly5.iam
    Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
    Any ideas whats wrong?
    *Expert Elite*
    Curtis_Waguespack
    01-24-2013 09:19 AM in reply to: 128848
    Hi 128848,
    First I've changed the Dim oDoc  as PartDocument to Dim oDoc  as Document to avoid the first issue (Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument').
    Secondly, I've changed the line If oWorkPlane.Constraint.IsActive("Mate:1")=True Then to Constraint.IsActive("Mate:1")=True.
    I think this will work for you now.
    I hope this helps.
    Curtis
    'define document
    Dim oDoc As Document
    End If
    Next
    01-25-2013 06:52 AM in reply to: Curtis_Waguespack
    Awesome! Now we`re getting somewhere. No errors, however, the work plane is still visible.
    And also, instead of specifying that specific mate "Mate:15" is there a symbol I can put in so it dosent matter if it`s mate 1 or mate 110?
    Thanks for your help so far :smileyhappy:
    *Expert Elite*
    Curtis_Waguespack
    01-25-2013 07:15 AM in reply to: 128848
    Hi 128848,
    I'm not following how the constraints are being used to determine if the workplanes should be visible? Can you describe your goal here again?
    Also, is your workplane in a part file or was it created in the assembly?
    I hope this helps.
    Curtis
    02-05-2013 11:37 AM in reply to: Curtis_Waguespack
    This one has slipped my mind.
    The tilted part has 2 planes (within the part, not the assembly) and these two planes are constrained to the other parts. When they are constrained I would like to turn off the visibility. Horrible explanation, but did you get it?
