• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    iLogic code to embed externally ran rule to ipt.
    117 Views, 1 Replies
    01-12-2013 02:28 PM
    Hi Folks,
    I have put together some ilogic code which is embedded within a part template, this auto populates the iproperties with the profiles length,width and thickness, and also automatically updates when any changes are made to the said profile When I hit save.
    This works a treat when creating new parts, the problem arises when re-using old parts from previous jobs (Which is a regular occurrence),prior to when the code was created.
      So I have to run the code as an external rule, but this has caught me,and a few other people out, as we have forgotten to run the rule after making a change to the part so the iproperties aren't automatically updated.
     My question is, is there a snippet of code that I could add to my code, which embeds the the externally ran rule to the Ipt?
    I hope this makes sense???
    Please use plain text.
    pcrawley
    Re: iLogic code to embed externally ran rule to ipt.
    01-13-2013 01:19 PM in reply to: Fleagle8t
    You could run "Code Injector".  You can batch select all your old files and add your rule to them. Easy.
    I have to say that Code Injector is the greatest iLogic-related tool ever.  Being able to push code into parts that previously didn't have code - or modify code on parts - or run code to change models... It's just awesome.
    http://beinginventive.typepad.com/being-inventive/2012/02/injecting-ilogic-code-and-ilogic-event-tri...
