• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    iLogic code not functioning correctly
    149 Views, 16 Replies
    02-08-2012 01:35 PM
    The problem is that for some reason the bolts constraints are not suppressing.  It is simple on/off code but for some reason I am still getting constraint and component errors.
    Had to add " " to get code to post...I don't actually have them in my code.
    Here is the code:
    "If HopperType = "10TADL" Or HopperType = "12BH" Or HopperType = "12TAD" Then
    Component.IsActive("Component Pattern 1:1") = True
    Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:1") = True
    Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:2") = True
    Component.IsActive("Hex Nut - Inch 5/16 - 18:1") = True
    Component.IsActive("Hex Nut - Inch 5/16 - 18:2") = True
    Constraint.IsActive("Insert:1") = True
    Constraint.IsActive("Mate:80") = True
    Constraint.IsActive("Mate:78") = True
    ElseIf HopperType <> "10TADL" Or HopperType <> "12BH" Or HopperType <> "12TAD" Then
    Component.IsActive("Component Pattern 1:1") = False
    Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:1") = False
    Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:2") = False
    Component.IsActive("Hex Nut - Inch 5/16 - 18:1") = False
    Component.IsActive("Hex Nut - Inch 5/16 - 18:2") = False
    Constraint.IsActive("Insert:1") = False
    Constraint.IsActive("Mate:80") = False
    Constraint.IsActive("Mate:78") = False
    End If"
    Distinguished Contributor
    Ktelang
    Re: iLogic code not functioning correctly
    02-08-2012 02:13 PM in reply to: Breeze104
    As you are getting your bolts and nuts suppressed
    I assume you have a custom level of representation
    Please find the attached simulated condition the suppression condition is something
    different : open model Bolted and unsuppress the connections
    I have modeled 1 bolted connection and other place from content center at the same location
    And then run the rules
    Else please share the sample file
    Config :: Intel (R) Xeon (R) CPU E5506 @ 2.13 GHz, 8 GB, 64bit win7
    Valued Mentor
    swordmaster
    02-08-2012 02:50 PM in reply to: Breeze104
    If you are simply trying to suppress your hardware there is no need to suppress the constraints
    try "commenting out" those lines and run the rules again
    Similarly there is no need to suppress each instance of your pattern
    Inventor 2010 Certified Professional
    Valued Contributor
    02-09-2012 04:32 AM in reply to: swordmaster
    That is the problem I originally did just suppress the component pattern, but it still thru constraint errors eventhough they should have been shut off in all hopper types except those three listed.
    Valued Contributor
    02-09-2012 05:23 AM in reply to: Breeze104
    Even coding it like this...the Component Pattern 1:1 is still active and giving error in Design Doctor.
    If HopperType = "10TADL" Then
    ElseIf HopperType = "12BH" Then
    ElseIf HopperType = "12TAD" Then
    Else
    End If
    Valued Contributor
    02-09-2012 05:49 AM in reply to: Breeze104
    I wanted to give a quick thanks to ya'all for your help so far...
    Eventhough it has solved the issue, I was able to go though all the other rules and really thin them down....THANKS
    Valued Contributor
    02-09-2012 06:03 AM in reply to: Breeze104
    After using the form I created and switching hopper types I am finding out that the other hopper types that are suppsed to have the nuts and bolts in them aren't correct either.
    What is happening is that the nuts and bolts are active but the constraints to put them in place are not activating, so they end up where ever on the end plate of the hopper.
    See Pic : http://screencast.com/t/c9SHhdJL
    Valued Contributor
    02-09-2012 06:31 AM in reply to: Breeze104
    Seems my typing skills need some help...
    Was suppsed to read "Eventhough it hasn't solved the issue......"
    Sorry about that
    Valued Contributor
    02-09-2012 06:46 AM in reply to: Breeze104
    One other thing I have noticed looking over things.....is that if I right click on Component  Patteren 1:1 is shows a check mark by "Suppressed", but for some reason it is throwing the "Component Pattern failure" error in Design Doctor.
    Valued Mentor
    swordmaster
    02-09-2012 07:20 AM in reply to: Breeze104
    Ok,
    I made a small test to show how this pattern suppression works.
    This code suppresses  the pattern named "my_pattern" and all of the instances of that pattern.
    Based on the value of the parameter "my_configuration"
    It does not to "touch" the constraints........these are still needed
    trigger
    = iTrigger0
    if
    my_configuration = 0 then
    Component.IsActive
    ("my_pattern") = False
    else
    Component.IsActive
    ("my_pattern") = True
    end if
    iLogicVb.UpdateWhenDone
    = True
