Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
iLogic and sheetmetal Properties
- Highlight
- Email to a Friend
As starting on my first iLogic project please feel free to contribute as much a possible.
I intend to do the following;
1.) Retrieve the sheet metal material/style from an assembly and store into a String or a Text parameter
2.) Fetch the list of sheet metal styles in the Inventor library (as plenty of them have been populated and shared among as a library)
3.) Change the sheet metal material and style
I am guessing (1) and (3) should be vey similar.
A l s o : if someone can let me know on how to remove duplicate items in a list parameter ??
Thanking as a down payment ;0
Wajih
Re: iLogic and sheetmetal Properties
- Highlight
- Email to a Friend
Sets a style as current:
Dim style As String style = "your sheet metal rule" Dim oSheetMetalCompDef As SheetMetalComponentDefinition oSheetMetalCompDef = ThisDoc.Document.componentdefinition oSheetMetalCompDef.SheetMetalStyles.Item(style).Activate
Sets a material:
iProperties.Material = "your material"
Retrievies material:
yourVariable = iProperties.Material
Retrieves active style:
Dim oSheetMetalCompDef As SheetMetalComponentDefinition oSheetMetalCompDef = ThisDoc.Document.componentdefinition yourStyle = oSheetMetalCompDef.ActiveSheetMetalStyle.Name
This retrieves each style in the document and displays a dialog for each one (there's better ways to do this but I'm not sure what your goal is):
Dim style As String Dim styleCount As Integer Dim oSheetMetalCompDef As SheetMetalComponentDefinition oSheetMetalCompDef = ThisDoc.Document.componentdefinition styleCount = oSheetMetalCompDef.SheetMetalStyles.Count For i = 1 To styleCount style = oSheetMetalCompDef.SheetMetalStyles.Item(i).Name MsgBox(style) Next
- Highlight
- Email to a Friend
Thank you Mike.
Just have a few supplimentary questions;
It works for the part (.ipt), but when I try to retrive the styles for individual parts from an assembly (.ism); it prompts for an error that styles could not be retrived.
But I will make this work by fetching the styles within the part and then pass the part variable to the assembly.
Kudos.
- Highlight
- Email to a Friend
That's because the code above is drilling into a part definition, it will fail if you use it on an assembly because an assembly doesn't have part properties. The code could be rewritten to drill into the part's definition from the assembly level, but I just had a large project dropped on my desk and don't have time to cook it up for you.
- Highlight
- Email to a Friend
Thank you for your support and dedication to help others out.
This is how I got my task working, except for the matter that the sheetmetal style does not update until I manually go to the part level and update it via rules.
' ********** Rule for the Assembly ***********************
' **** Key paramters for the assembly *****************
' 1) strSelectedStyle (Text)
' 2) optChangeStyle (True/False)
If optChangeStyle = True Then
Parameter( "bracket_wraper:1, "srtDesiredStyle") = strSelectedStyle
End If
' ********** Rule for the Sheetmetal Part ***********************
' ************** Key paramters for the ipt ********************
' 1) strOriginalStyle (Text)
' 2) srtDesiredStyle (Text)
srtOriginalStyle = SheetMetal.GetActiveStyle
SheetMetal.SetActiveStyle(srtDesiredStyle)
Is there a way to pass the SheetMetal style directly from the assembly to the part file so that all the updates are synced.
Thank you
