• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Accepted Solution
    iLogic: Printing
    232 Views, 3 Replies
    12-12-2012 05:50 PM
    I dont want to print directly from code but simply open the "print drawing" tab via iLogic
    Any ideas,
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: iLogic: Printing
    12-13-2012 07:35 AM in reply to: LewisLusby
    Hi  LewisLusby,
    You can use this line to programatically "push" the print button:
    ThisApplication.CommandManager.ControlDefinitions.Item("AppFilePrintCmd").Execute
    Also just a tip: you might have better luck searching and asking questions of this type on the Inventor Customization forum:
    http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    12-16-2012 07:06 PM in reply to: Curtis_Waguespack
    Just what I was after.
    Much appreciated Curtis,
    Active Contributor
    ComputerGuru666
    03-01-2013 05:48 AM in reply to: LewisLusby
    Is there a way to catch this command before it executes?
    Example: I want to use an iLogic form that is triggered via the iTrigger that users have to prompt to select what kind of print this is "RELEASE, REFERENCE, or DRAFT" once there selection is made the the form exits, the "Plot Stamp" in the title block is updated based on the selection and the print window is excuted with this command.
    Now I have all this worked out but being that this isnt a perfect world the problem is users still sometimes click the print button which does not prompt them for the print type which is a problem. Which is why I am wondering if a user clicks the print button I can prompt the iLogic form before the print options window comes up?
    Thank you
    Computer Specs:
    Windows 7 (64 Bit) Pro. SP1, Inventor 2014 Pro, 3D Connexion SpaceNavigator (Driver 3.15.2)
    Motherboard: ASUS Rampage IV Extreme x79 Socket 2011
    Processor: Intel Core i7 Six Core Sandy Bridge-E 3.2GHz OCed to 4.7GHz (Under Water)
    RAM: G.Skill Ripjaw Z-Series 32 gig quad channel of RAM 1800MHz OCed to 2133MHz
    Video Card: 2x Nvidia Geforce GTX 670 (Running Six (6) Monitors)
    Monitors: [Primary = 2x 24in HD Asus Wide Screen][Secondary = 2x 22in HD LG Wide Screen][Tertiary = 2x 19in Samsung Full Screen]
    Primary Hard Drive: OCZ Vertex IV 256 GB Solid State Drive
    Secondary Hard Drive: OCZ Vertex III 120 GB Solid State Drive
