Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
iLogic Multivalue Parameter
- Highlight
- Email to a Friend
Hi All, do you know how to populate an Inventor Multivalue PARAMETER using a For cycle in iLogic according to a variable index corresponding to a different number of array items?
for example:
i grab some data from a Rule and populate an Arraylist variable. I trace the number of instances using a counter. after the data acquisition I want to populate the Multivalue Parameter with the acquired values.
No problem browsing the Arraylist parameter: MyArraylist.(Index)... but what about the Multivalue parameter?
the MultiValue.SetList("Multivalue Parameter", Value 1, Value 2, ... , Value N) provide a defined number of data and cannot be set dynamically according to an Index.
thank you in advance
Re: iLogic Multivalue Parameter
- Highlight
- Email to a Friend
Out of my breif knowledge I would suggest you can use another Array, populate that and then send it to the paramer.
i.e.
' Your extracted value
Dim MyOriginalArray as New ArrayList
MyOriginalArray = .......
'Declare an arbitrary array
Dim lstSecond as New ArrayList
' filter out as however you would like
For i = 1 to 10
lstSecond.add(MyOriginalArray.item(i))
Next i
'Populate the paramter
Multivalue.List(YourParameter") = lstSecond
Hope this helps
- Highlight
- Email to a Friend
Multivalue.List("MyParameter") = ArrayList was exactly what I was missing. It works perfectly without any cycle for filling in all he values and it depends on how many values are stored into ArraList.
Great, Thank you!
