• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    iLogic Issues with unsupressing iassembly members within master assembly
    29 Views, 0 Replies
    01-02-2013 04:57 AM
    Fairly new to all the ilogic rules and programming. Have got reasonably far....but have hit a brick wall and am desperate for help....before i go crazy..
    Basically I created an iassembly with 18 members and placed within a master assembly which has in total 4 iassemblies in with 18 memebers each.
    they each have unique part numbers, problem is trying to unsuprress the part numbers, once I have supressed them.
    The parts change dependent on the length, the other lengths are supressed, when I come to select the correct length to unsupress the part its comes up with ERROR in rule Component: The Component named "11111:1" was not found.
    Example of the rule written that doesnt work to unsupress members, once the lngth has changed..
    MultiValue.SetList("LENGTH", "10","15","17.5","20","25","30","33","35","38","40","45","47","48","50","55","60","65")
    If  SINK_REQUIRED = "NO" And LENGTH = "10" Then
    Component.IsActive("11111:1")= False
    Else If  SINK_REQUIRED = "YES" And LENGTH = "10" Then
    Component.IsActive("11111:1")= True
    Else If  SINK_REQUIRED = "NO" And LENGTH = "15" Then
    Component.IsActive("22222:1")= False
    Else If  SINK_REQUIRED = "YES" And LHD_LENGTH = "15" Then
    Component.IsActive("22222:1")= True
    End If
    Please help????????? Thanks
    Please use plain text.
