Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
iLogic Issues with unsupressi ng iassembly members within master assembly
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
31 Views, 0 Replies
01-02-2013 04:57 AM
Fairly new to all the ilogic rules and programming. Have got reasonably far....but have hit a brick wall and am desperate for help....before i go crazy..
Basically I created an iassembly with 18 members and placed within a master assembly which has in total 4 iassemblies in with 18 memebers each.
they each have unique part numbers, problem is trying to unsuprress the part numbers, once I have supressed them.
The parts change dependent on the length, the other lengths are supressed, when I come to select the correct length to unsupress the part its comes up with ERROR in rule Component: The Component named "11111:1" was not found.
Example of the rule written that doesnt work to unsupress members, once the lngth has changed..
MultiValue.SetList("LENGTH", "10","15","17.5","20","25","30","33","35","38","40","45","47","48","50","55","60","65") If SINK_REQUIRED = "NO" And LENGTH = "10" Then Component.IsActive("11111:1")= False Else If SINK_REQUIRED = "YES" And LENGTH = "10" Then Component.IsActive("11111:1")= True Else If SINK_REQUIRED = "NO" And LENGTH = "15" Then Component.IsActive("22222:1")= False Else If SINK_REQUIRED = "YES" And LHD_LENGTH = "15" Then Component.IsActive("22222:1")= True
End If
Please help????????? Thanks
