• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    iLogic If then formulas
    159 Views, 5 Replies
    02-06-2013 12:40 AM
    Hi!
    I have an assembly with several parts where I use a pattern to duplicate the parts in the height. I cannot use the pattern sideways due to different center distances between the parts. I could get this distance by using several patterns, but I rather not if there is another way.
    I have made a code for suppressing the parts in element 2 if the same part is suppressed in element 1.
    IfComponent.IsActive("FB-07 midtstykke-001:1")=False ThenComponent.IsActive("FB-07 midtstykke-001:2")=FalseElseComponent.IsActive("FB-07 midtstykke-001:2")=TrueEndIf
    which works fine, however, I only want the rule to run if two criterias are true. I`ve tried the following:
    If Component.IsActive("FB-02 midtstykke-001:1") = False And No = 2 Then
    component.IsActive("FB-07 midtstykke-001:2") = False
    Else
    Componen.....
    End if
    But this rule runs even if No = 3, which it shouldnt. Any ideas?
    Thanks in advance :smileyhappy:
    Please use plain text.
    Valued Contributor
    Re: iLogic If then formulas
    02-06-2013 02:37 AM in reply to: 128848
    I usually use this method as I have had trouble using 'AND'.
             If No = 2 Then
             Else
             Componen.....
    Else
    Component...
    End if
    It's basically just an IF within an IF
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    02-06-2013 06:44 AM in reply to: waynehelley
    Nice, Thank you!
    However, this code does not turn the part back on if Component.IsActive("FB-02 midtstykke-001:1") = True
    If Component.IsActive("FB-07 midtstykke-001:1")=False Then	IfNo=2 ThenComponent.IsActive("FB-07 midtstykke-001:2")=FalseElseComponent.IsActive("FB-07 midtstykke-001:2")=TrueEndIf	EndIf
    IfComponent.IsActive("FB-07 midtstykke-001:1")=TrueThen IfNo=2 ThenComponent.IsActive("FB-07 midtstykke-001:2")=TrueElseComponent.IsActive("FB-07 midtstykke-001:2")=FalseEndIfEndIf
    What would the code be if I should have used 1 if then code? Is it better to use 1 more complex then 2 "easier" code?this code will be copied maaaaany times!
    02-06-2013 06:45 AM in reply to: 128848
    some thing happend there.
    Basically the same formula, but if compon... = True then
    if No = 2 then
    Com....
    Valued Contributor
    02-06-2013 07:22 AM in reply to: 128848
    You shouldn't have to copy the code twice with 'False' replaced with 'True.  The function after 'Else' should do this for you.
    What is 'No'?  If it is a parameter, then you will need to replace it with 'Parameter("No")'.
    I'm not sure I understand what you are wanting to achieve but try pasting the following.
    If Component.IsActive("FB-02 midtstykke-001:1") = False Then
             If Parameter("No") = 2 Then
             Component.IsActive("FB-07 midtstykke-001:2") = False
             Else
             Component.IsActive("FB-07 midtstykke-001:2") = True
    Else
    component.IsActive("FB-07 midtstykke-001:2") = True
    End if
    Wayne Helley
    *Expert Elite*
    mrattray
    02-06-2013 09:55 AM in reply to: 128848
    The "And" function works just fine for me in my applications, I use it extensively. Can you post your files or an example that shows the same problem for me to look at?
    Mike (not Matt) Rattray
