• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Accepted Solution
    iLogic Excel date problem
    266 Views, 11 Replies
    01-07-2013 07:15 AM
    I want iLogic to look up todays date in an excel file and then pull information from that row.
    The problem I have is that it doesn't seem to like / or -  so I am not sure how to format the date.
    How would I format my date in Excel so that it matches the wway Inventor stores it in iproperties>Project>Creation Date?
    Any help would be much appreciated.
    Inventor 2013
    DwgNum = iProperties.Value("Custom", "Dwg Number")
    Client = iProperties.Value("Project", "Vendor")
    Description = iProperties.Value("Project", "Description")
    DrawingType = iProperties.Value("Custom", "Drawing Type")
    author = iProperties.Value("Summary", "Author")
    Date2 = iProperties.Value("Project", "Creation Date")
    i = GoExcel.FindRow("C:\Users\jwilloughby\Desktop\Drawing_Log_2004.xls", "2013", "TEST", "=", Date2)
    DwgNum = GoExcel.CurrentRowValue("DWG #")
    Description = GoExcel.CurrentRowValue("DESCRIPTION")
    Client= GoExcel.CurrentRowValue("COMPANY")
    DrawingType= GoExcel.CurrentRowValue("DRAWING TYPE")
    author= GoExcel.CurrentRowValue("DRAWN BY")
    iProperties.Value("Custom", "Dwg Number") = DwgNum
    iProperties.Value("Project", "Vendor") = Client
    iProperties.Value("Project", "Description") = Description
    iProperties.Value("Custom", "Drawing Type") = DrawingType
    iProperties.Value("Summary", "Author") = author
    iLogicVb.UpdateWhenDone = True
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: iLogic Excel date problem
    01-07-2013 07:36 AM in reply to: jamjumpin
    Hi jamjumpin,
    I don't see a reference to a date in your example code. Could you post what you've tried so far?
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    01-07-2013 07:43 AM in reply to: Curtis_Waguespack
    Sorry I just updatead it.
    This code doesn't work anyway, it says "Invalid cast from 'DateTime' to 'Double'."
    Active Contributor
    01-07-2013 07:47 AM in reply to: jamjumpin
    Ultimately I want it to find all the references to todays date and display the information from the cells next to it so you can choose which is the correct one.
    i.e.
    Column 1 is date
    COlumn 2 is description
    It finds all the dates that match in column 1 and then shows a multivalue box with the corresponding info from Column 2.
    When the user picks a value from the multivalue list that is the row it then reads all teh infon from.
    Is this even possible in iLogic?
    *Expert Elite*
    Curtis_Waguespack
    01-07-2013 09:54 AM in reply to: jamjumpin
    Hi jamjumpin,
    Here's an example rule. Note if you get an error from Copy and Pasting from this forum, try the attached *.txt file.
    I hope this helps.
    Curtis
    'define the XLS to look at
    myXLS = "U:\iLogic examples\Excel Date lookup.xlsx"
    GoExcel.Open(myXLS, "Sheet1")
    'create an array list to hold found values
    Dim myArrayList As New ArrayList
    'look at the first 1000 rows of the Excel file
    For rowCheck = 2 To 1000
    	'read the value of the column A
    	Dim myCell  As Double
    	myCell = GoExcel.CellValue("A" & rowCheck)
    	'format the found value as a date
    	Dim myDate As DateTime
    	myDate = Date.FromOADate(myCell)
    	'set the current date from the computer system date
    	Dim curDate As String
    	curDate = DateString
    	 'compare the found value to the current date
    	If myDate = curDate Then
    	 	'get the description
    		sDescription = GoExcel.CellValue("B" & rowCheck)
    		'add the description to the list
    		myArrayList.add(sDescription)
    	End If
    Next
    myName= ThisApplication.GeneralOptions.UserName
    'ensure that the current date was found (and added to the array list)
    If myArrayList.Count = 0 Then
    MessageBox.Show("The current date was not found in the Excel file." , "iLogic")
    Else
    'present the list to the user
    myDesc = InputListBox("Yo, " & myName & " select one of these bad boys!", myArrayList, myArrayList.Item(0), "iLogic", "Selection List")
    'present the result
    MessageBox.Show("You selected: " & myDesc, "iLogic")
    End If
    Active Contributor
    01-07-2013 11:47 AM in reply to: Curtis_Waguespack
    Thank you very much, I can probab;y use this to trigger the other functions I need it to do.
    Active Contributor
    01-07-2013 11:50 AM in reply to: jamjumpin
    It didn't work at first, and this may be help to anyone else having the problem.
    My excel was formatted in the international style of date rather than the USA one.
    New Member
    01-07-2013 12:28 PM in reply to: jamjumpin
    If it helps, rather than grab it from Excel, you can just use DateString to insert today's date, sort of like:
    iProperties.Value("Custom", "DATE")=DateString
    This would show up in the format 01-07-2013.  I know it's not the way you were trying to do it, but it might save you some headache in the future.
    Scott Hoffmeyer
    Inventor Pro 2013 - SP1.1
    Dell Precision M6500
    i7 CPU Q 820 @1.73GHz
    NVIDIA Quadro FX 2800M
    Active Contributor
    01-07-2013 12:34 PM in reply to: SHoffmeyer
    The date is being discarded, it's purely for refernce to grab other info from the Excel sheet.
    Active Contributor
    01-07-2013 12:38 PM in reply to: Curtis_Waguespack
    Thank you, the code seems to work now I've added some extra stuff to the end. I have a few questions.
    How do I get it to match the international form of the date instead of the US one? As in dd/mm/yyyy
    Is there a way to just read the excel file instead of using the open command? iEverytime I run the command I get the following message, even when it isn't open:
    Drawing_Log.xls is already open. Reopening will cause any changes you made to be discarded. Do you want to reopen Drawing_Log.xls?
     Is there a way to stop it asking the following message at the end of the rule too?
    Do you want to save the changes you made to 'Drawing_Log.xls'?
    The final thing is that sometimes I get the following error when I run the rule. If I don't change anything and run the rule again it works fine. Any ideas?
    Error in rule: Rule3, in document: New Drawing iLogic.idw
    Object reference not set to an instance of an object.
    Once again, thanks so much!
