Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
iLogic Excel date problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I want iLogic to look up todays date in an excel file and then pull information from that row.
The problem I have is that it doesn't seem to like / or - so I am not sure how to format the date.
How would I format my date in Excel so that it matches the wway Inventor stores it in iproperties>Project>Creation Date?
Any help would be much appreciated.
Inventor 2013
DwgNum = iProperties.Value("Custom", "Dwg Number") Client = iProperties.Value("Project", "Vendor") Description = iProperties.Value("Project", "Description") DrawingType = iProperties.Value("Custom", "Drawing Type") author = iProperties.Value("Summary", "Author") Date2 = iProperties.Value("Project", "Creation Date") i = GoExcel.FindRow("C:\Users\jwilloughby\Desktop\Drawing_Log_2004.xls", "2013", "TEST", "=", Date2) DwgNum = GoExcel.CurrentRowValue("DWG #") Description = GoExcel.CurrentRowValue("DESCRIPTION") Client= GoExcel.CurrentRowValue("COMPANY") DrawingType= GoExcel.CurrentRowValue("DRAWING TYPE") author= GoExcel.CurrentRowValue("DRAWN BY") iProperties.Value("Custom", "Dwg Number") = DwgNum iProperties.Value("Project", "Vendor") = Client iProperties.Value("Project", "Description") = Description iProperties.Value("Custom", "Drawing Type") = DrawingType iProperties.Value("Summary", "Author") = author iLogicVb.UpdateWhenDone = True
Re: iLogic Excel date problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi jamjumpin,
I don't see a reference to a date in your example code. Could you post what you've tried so far?
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry I just updatead it.
This code doesn't work anyway, it says "Invalid cast from 'DateTime' to 'Double'."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ultimately I want it to find all the references to todays date and display the information from the cells next to it so you can choose which is the correct one.
i.e.
Column 1 is date
COlumn 2 is description
It finds all the dates that match in column 1 and then shows a multivalue box with the corresponding info from Column 2.
When the user picks a value from the multivalue list that is the row it then reads all teh infon from.
Is this even possible in iLogic?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi jamjumpin,
Here's an example rule. Note if you get an error from Copy and Pasting from this forum, try the attached *.txt file.
I hope this helps.
Curtis
'define the XLS to look at
myXLS = "U:\iLogic examples\Excel Date lookup.xlsx"
GoExcel.Open(myXLS, "Sheet1")
'create an array list to hold found values
Dim myArrayList As New ArrayList
'look at the first 1000 rows of the Excel file
For rowCheck = 2 To 1000
'read the value of the column A
Dim myCell As Double
myCell = GoExcel.CellValue("A" & rowCheck)
'format the found value as a date
Dim myDate As DateTime
myDate = Date.FromOADate(myCell)
'set the current date from the computer system date
Dim curDate As String
curDate = DateString
'compare the found value to the current date
If myDate = curDate Then
'get the description
sDescription = GoExcel.CellValue("B" & rowCheck)
'add the description to the list
myArrayList.add(sDescription)
End If
Next
myName= ThisApplication.GeneralOptions.UserName
'ensure that the current date was found (and added to the array list)
If myArrayList.Count = 0 Then
MessageBox.Show("The current date was not found in the Excel file." , "iLogic")
Else
'present the list to the user
myDesc = InputListBox("Yo, " & myName & " select one of these bad boys!", myArrayList, myArrayList.Item(0), "iLogic", "Selection List")
'present the result
MessageBox.Show("You selected: " & myDesc, "iLogic")
End If
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you very much, I can probab;y use this to trigger the other functions I need it to do.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It didn't work at first, and this may be help to anyone else having the problem.
My excel was formatted in the international style of date rather than the USA one.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If it helps, rather than grab it from Excel, you can just use DateString to insert today's date, sort of like:
iProperties.Value("Custom", "DATE")=DateString
This would show up in the format 01-07-2013. I know it's not the way you were trying to do it, but it might save you some headache in the future.
Scott Hoffmeyer
Inventor Pro 2013 - SP1.1
Dell Precision M6500
i7 CPU Q 820 @1.73GHz
NVIDIA Quadro FX 2800M
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The date is being discarded, it's purely for refernce to grab other info from the Excel sheet.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you, the code seems to work now I've added some extra stuff to the end. I have a few questions.
How do I get it to match the international form of the date instead of the US one? As in dd/mm/yyyy
Is there a way to just read the excel file instead of using the open command? iEverytime I run the command I get the following message, even when it isn't open:
Drawing_Log.xls is already open. Reopening will cause any changes you made to be discarded. Do you want to reopen Drawing_Log.xls?
Is there a way to stop it asking the following message at the end of the rule too?
Do you want to save the changes you made to 'Drawing_Log.xls'?
The final thing is that sometimes I get the following error when I run the rule. If I don't change anything and run the rule again it works fine. Any ideas?
Error in rule: Rule3, in document: New Drawing iLogic.idw Object reference not set to an instance of an object.
Once again, thanks so much!
