• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    iLogic Content Center Replace Nuts
    643 Views, 4 Replies
    06-07-2012 07:05 AM
    I have the example working which will replace Bolts:
    ref: http://forums.autodesk.com/t5/Autodesk-Inventor/Changing-C-C-component-Automation/td-p/2736623
    but swapping the code to replace nuts is giving me grief. How do you identify the content center paths?
    ie I have tried:
    replacer.Replace("nut:1", "Fasteners:Nuts:Hex", "ISO 8675 - M30 x 2DIN EN")
    replacer.Replace("nut:1", "Fasteners:Nuts:Hex", "ISO 8675 - M30 x 2")
    replacer.Replace("nut:1", "Fasteners:Nuts:Hex ", "DIN EN 28675 M30 x 2")
    Thanks MES
    Please use plain text.
    Re: iLogic Content Center Replace Nuts
    06-14-2012 04:21 AM in reply to: MarkESmith
    I now have this working  - but have failed at the next step - swapping out from a custom content center.
    Possible?
    Employee
    06-15-2012 02:22 PM in reply to: MarkESmith
    Mark,
     I posted a reply at http://forums.autodesk.com/t5/Autodesk-Inventor/Changing-C-C-component-Automation/m-p/3378327, but it sounds like you're past that point.
     The code should work on a custom CC library.  Can you provide some details about the family annd member names in the custom library?
     Although it's a custom library, are you using the parts as standard (the designer cannot modify an individual part file after he has placed it from the CC)?
    Mike Deck
    Software Developer
    DLS - Mechanical Design
    Autodesk, Inc.
    Active Contributor
    12-20-2012 10:23 AM in reply to: MarkESmith
    I try to do a similar replace from content center but I keep getting an error that content center family is not found.
    I have read all related posts and tried many things, im out of ideas.
    I might do something entirely wrong or I might just have a small typo, but the result is still the same error.
    Any help would be great. See attachment
    Thanks in advance,
    Arnold
    Active Contributor
    12-21-2012 01:39 AM in reply to: MarkESmith
    Seems to be nothing more then a typo.
    What I did was to add the nut in the content center to favorites. This way you can right click and rename it.
    Use this to copy the foldernames and the partname so you dont have any chance of a typo. Though I didnt see any typo, it works now.
