• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    chrisrodway
    Accepted Solution
    iFeature Placement
    128 Views, 2 Replies
    01-21-2013 03:32 AM
    Im just starting to look at Ifeatures to help me design, but even though my sketch is fully constrained when I place the iFeature with multiple references i can still move it using the arrows. Any ideas how i could place them more accurately
    Cheers
    Chris
    Design Engineer
    Sheffield, UK
    Cheers
    Chris Rodway
    Design Engineer
    Sheffield, UK
    Please use plain text.
    Product Support
    Re : iFeature Placement
    01-22-2013 06:01 AM in reply to: chrisrodway
    Thank you for having posted your question on the discussion group.
    In fact when you want to select an ifeature and insert it you need to:
    1) select the ifeature from the library to select an existing face of your part 2) place approximately the position of the ifeature 3) change (if necessary) the values of the parameters 4) open the sketch of the inserted ifeature and at this time you have the possibility to fully constrain (position) the sketch to the existing geometry.
    Here are some links which could interest you:
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1500-Parts1500/1580-iFeature15...
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0351-iFeature3...
    I hope that helps.
    Please, mark any response clicking on "Accept as Solution" button if it answers your question
    Nicolas.Bourquin
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    chrisrodway
    01-24-2013 03:44 AM in reply to: Nicolas.Bourquin
    Hi Nicolas,
    Ive found out what I was doing wrong thanks to your reply and links. I was placing my Ifeatures without
    activating the sketch, this causes the iFeature to have no constraints.
    Cheers for the reply
    Chris Rodway
    Design Engineer
    Sheffield, UK
    Cheers
    Chris Rodway
    Design Engineer
    Sheffield, UK
