• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    iAssembly Pattern not updating correctly!
    88 Views, 7 Replies
    12-21-2007 07:01 AM
    See attached dataset.
    If you change from "3 - WITH Rounds" to "6 - WITHOUT Rounds", some elements
    in the pattern are not being excluded.
    T. Ham
    CAD Automation & Systems Administrator
    CDS Engineering BV
    HP xw4300 Workstation
    Dual Pentium XEON 3.6 Ghz
    4 GB SDRAM
    NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
    250 GB SEAGATE SATA Hard Disc
    3Com Gigabit NIC
    Windows XP Professional SP2
    Autodesk Inventor Series 10 SP3a
    Autodesk Inventor Suite 2008 SP1
    Please use plain text.
    Re: iAssembly Pattern not updating correctly!
    12-21-2007 07:02 AM in reply to: *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    And a videoclip showing the problem...
    T. Ham
    CDS Engineering BV
    4 GB SDRAM
    3Com Gigabit NIC
    12-21-2007 07:37 AM in reply to: *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    I "solved" this issue by setting the number elements of the pattern to "1"
    when it is being suppressed (excluded).
    But I still think that the iAssembly is not correctly updating when you
    switch from one element to another...
    T. Ham
    CDS Engineering BV
    4 GB SDRAM
    3Com Gigabit NIC
    Distinguished Contributor
    12-21-2007 07:49 AM in reply to: *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    I had a similar problem:
    http://discussion.autodesk.com/thread.jspa?messageID=5772844
    Inventor Routed Systems 2010
    Subscription Advantage Pack SP3
    Vault Collaboration 2010
    Windows 7 x64
    Dell Precision M6400 Covet
    04-15-2008 10:41 AM in reply to: *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    I am having the same issue. Attached is a picture showing the pattern that is excluded and the pattern still showing up in the model. When I look at the BOM the excluded parts are not there and if I make a drawing the excluded parts do not show up either. Has anyone figured out what the problem is?
    N-
    04-15-2008 11:00 AM in reply to: *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    I'm not sure this is the same issue, but I have an iassembly stairway modeled that acts the same way updating the iassembly.
    But when placing the iassembly child in an assembly it always depicts the correct assembly.
    So, what I am trying to say is that my iassemblies do not update correctly until it is placed into an assembly.
    HTH
    kp
    btw: IV11
    04-15-2008 02:26 PM in reply to: *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    When did iassemblies\iparts start working?
    Valued Contributor
    04-16-2008 10:57 AM in reply to: *Teun Ham \(IV10 SP3 / IV2008 SP1\)
    Teum,
    I have verified the behavior on R2008. But, I am not able to reproduce it on R2009. It seems to work there.
    Johnson Shiue
    Inventor QA Tech Lead
