Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
how to show parts in different arrangemen ts?
- Highlight
- Email to a Friend
- Report Inappropriate Content
Excuse me could someone tell me how to to make a part have different arrangements (eg a suppliers hydraulic cylinder extracted and collapsed) , and then show the part in an assembly in the two different positions. I am not sure if Iparts is the way to go, as I want both the arrangements to be displayed as the same part in the BOM.... the equivalent term is 'configurations' in solid works.
appreciate any assistance
Re: how to show parts in different arrangemen ts?
- Highlight
- Email to a Friend
if it's the same part (ie the part doesn't change) in the assembly then can do it 2 ways:
1) position reps - can modify existing constraints to say show an arm in 2 positions.
2) presentation .ipn file and tweak existing constraints within the assembly, to move the parts about. Arguably quite similar to position reps and yet another file to manage, but it's easier to use when moving lots of components, wanting to show trails (for exploded views) or wanting to move parts in a direction/rotation that isn't easy with the existing assembly constraints.
If you're trying to show an assembly in 2 positions with a changing component (e.g. spring in 2 states or say a wiring-loom in position a for assembly step 2 and position b when fully assembled) then it's a little more complicated. If it's a sub-assembly then can consider using the "flexible" option and leave a constraint open (or with a max/min limit). But if the modelling of the cad parts change then it's usually a little more complicated. Personally create a second part with it in it's second state and insert that into the assembly next to the original and use position reps or a ipn presentation to toggle whether each version is visible for each state (and turn the altered part's visibility off in the BOM).
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love
Lithium - helping nntp users with mania, depression and headaches
- Highlight
- Email to a Friend
Flexible sub assemblies for different positions of the same assembly.
Position Representations for drawing views.
Overlay view.
Inventor Professional 2014 Edu 64-bit
- Highlight
- Email to a Friend
Thanks for your response,
your second paragraph is the scenario I am talking about. I find the solution a little disheartening, In the assembly I will have 2 parts representing one part. One being the correct part number, the other a piece of reference geometry, this will mean in one drawing view (with the reference geometry) the balloon items will not be parametrically driven. The other concern is that if someone revises the 'actual' part in the future, the reference geometry part will be forgotten.
I guess there is no adequate work around in Inventor to replicate this solidworks functionality - so how do Inventor users get around this? Does every moving mart have to be represented as an assembly?
- Highlight
- Email to a Friend
lol...another solidworks can do this inventor cant post
no there is not a workaround
its a standard method
refer JDMAthers post or your VAR for proper training
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
coves92 wrote:
No, no, don't get me wrong, I think Inventor is as good as Solid works - if not worse.
that, my friend, I can accept
this link may help
- Highlight
- Email to a Friend
When do you have 2 parts in an assembly? can you provide examples as there might be solutions (or alternatives to your present work-flow).
I only ask as your original post mentions moving cylinders which I would have thought should be a sub assy (with max/min limits within the constraints for the stroke). This assembly gets placed in the main assembly and is set to "flexible" so it can move along it's free constraints.
The only times when you need 2 different versions of the same part is when the part physically changes like an o-ring in its natural shape and then stretched when fitted. Or, if you're explaining the steps of an assembly and needing to show how flexible components should be positioned at specific stages - e.g. a wire (built from a circle swept along a 3d-path) being fitted when the components are in 1 position in the build-process but those positions change when fully assembles and thus the wire's route changes accordingly. With this in mind, going back to a moving piston, the parts do not change, so there shouldn't be a need for multiple versions of them within the assembly.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
i would derive the supplier assembly into a part removing the piston and clevis.
I would also derive the assembly into a part of just the piston and clevis
break the links
then put the 2 parts together in an assy called your supplier part no.
you only have to add a couple constraints to make it work with flexibilty.
whole process should take you under 10 mins
then you only have 3 files to manage and dont have the overhead of all the suppliers IP
the link I gave you previously should point you in the right direction
