Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
how to save and import sketches from one file to another
Options
- Highlight
- Email to a Friend
130 Views, 5 Replies
05-28-2004 10:16 AM
I just wanted to know if you could make sketches in one part or file,
somehow save it with a name, then open a new or existing part file and
import that saved sketch. Is there a way to do this? Also, can you
make blocks, as we could in AutoCAD, in Inventor?
Re: how to save and import sketches from one file to another
Options
- Highlight
- Email to a Friend
05-28-2004 10:25 AM in reply to:
cadvice
somehow save it with a name, then open a new or existing part file and import that saved sketch. Is there a way to do this?
At least two ways.
1. RMB on the sketch in the browser in first file select Copy - then start a new file and RMB select Paste.
2. If the sketched is unconsumed in the first file (and you can always leave the sketch unconsumed by simply projecting the original to a new sketch and use that to create your features) then you can derive the original unconsumed sketch into another part. With this method if you make a change to the first it is updated in the derived (unless you break the link).
At least two ways.
*Hugh Henderson \(Autodesk\)
Options
- Highlight
- Email to a Friend
05-28-2004 10:36 AM in reply to:
cadvice
cadvice,
You can "Derive in" a sketch from another part.
1) Create and save a part that contains the sketch you with to "copy"
2) Create a new part, exit sketch and select Derived Component
3) In the Derived Part dialog, you can select which sketches you would
like to include
4) The sketches come in as reference geometry (and the best part is that it
is associative).
Best Regards,
Hugh Henderson (Autodesk)
"cadvice" wrote in message
news:25978185.1085764597338.JavaMail.jive@jiveforu m1.autodesk.com...
*Udaya Gunasena \(Autodesk\)
Options
- Highlight
- Email to a Friend
05-28-2004 11:35 AM in reply to:
cadvice
You can derive a consumed sketch if you make it shared and keep it visible.
"JDMATHER" wrote in message
news:31227799.1085765146569.JavaMail.jive@jiveforu m1.autodesk.com...
> At least two ways.
link).
Options
- Highlight
- Email to a Friend
05-28-2004 04:09 PM in reply to:
cadvice
You can open a sketch and select any part of it > Rmb and select copy. Do not close first sketch. Go to a second sketch. and past the selected sketch parts into it. Now constrain the geometry as needed.
Options
- Highlight
- Email to a Friend
11-08-2012 02:10 AM in reply to:
cadvice
I think the question was simple and it has common sense thing. You work and make sometime a sketch and you think: WOW this sketch I want use someday in the future, 5 minutes or 5 days/months, not important- first thing you think let''s save it!. That was the meaning of the question, Something what proe does since long long time ago!
Your "answers" are not answers, they want just to look as answers!
