• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    how to make a flat of this part??
    249 Views, 4 Replies
    11-08-2012 06:17 AM
    I Am trying to make a flat of this attached part. The dimensions are correct for the part but I am trying to make it such a way that I can form it using a die with a press break. I tried many different ways but inventor dosent seem to allow me to create a lofted flance using a 3-D profile sketch. any ideas on how o get this part modeled as a sheet metal and have a right flat opattern?
    Please use plain text.
    *Pro
    jletcher
    Re: how to make a flat of this part??
    11-09-2012 10:39 AM in reply to: jainildesai
    can you post a picture have not Loaded 2013
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    *Expert Elite*
    blair
    11-09-2012 11:51 AM in reply to: jainildesai
    You might be able to get this to work using the "Rolled" function within the Sheet-Metal portion of Inventor. You won't be able to get it to work using the 3D Sketch and Sweep.
    I really think that this is outside the scope of the Sheet-Metal module in Inventor
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Valued Mentor
    11-12-2012 05:20 AM in reply to: jainildesai
    ie, if the part relies upon the deformation of steel (as usually happens for complex shapes that are not split, formed and re-welded) then it cant be calculated by conventional means.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    11-12-2012 08:28 AM in reply to: jainildesai
    Hi Jain,
    for parts like this you need a special set of tools to unfold them. There are several out there as to name the first three on my mind:
    FTI Forming Suite
    3DQuickpress
    Logopress 3
    Regards
    Matthias
    Nihil Ex Nihilo
