• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Mike686
    how to control differents configuration in icopy
    62 Views, 0 Replies
    11-13-2012 01:53 PM
    hi everyone
    there something i want to do with an icopy aluminium panel i've done but i don't know if that can be done, and if it is how to do it
    here is my problem, i'm making aluminium panel with the icopy tool
    the way i do it is make a part with my skeleton and i had a couple more sketch that i use in the assembly level to insert some frame member..the i do my icopy template
    i also need to have on my panel one or more z bar depending on the height of the panel..
    i did a pdf of the configuration i want for the position of the Z
    i want to tell inventorto do this
    • if  the height is (i did not define the value yet) or less - put 1 Z in the center of the height
    • if  the height is (i did not define the value yet) or less - put 2 Z at equal distance to center of the height
    • if  the height is (i did not define the value yet) or less - put 1 Z in the center of the height and 2 Z at equal distance to center of the height
    • and finally if the height is higher i want to make a formula to determine the number of Z require and the put 1 Z at the centre and all the other at equal distance
    i dont know if i need to use ilogic, iassembly or another tool
    if you have any idea on how to do that please let me know
    also let me know if my problem or what i whant to acheive is unclear, i'll be glad to devellop more
    Product Design Suite 2013
    Please use plain text.
