• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    how to change default units to metric for inventor2013
    2972 Views, 3 Replies
    10-22-2012 01:12 AM
    how to change default units to metric for inventor2013? Now I have them set as imperial.
    thanks and regards
    Jis
    Please use plain text.
    Distinguished Contributor wh
    wh
    Betreff: how to change default units to metric for inventor2013
    10-22-2012 01:55 AM in reply to: jis.augustin
    You can select units by using special templates, whe setting up a new file.
    By default here with a German version, the template is called Norm.ipt and is in millimeters. And there are subfolders, too, for English or Metric setup.
    Walter
    *Pro
    Re: how to change default units to metric for inventor2013
    10-22-2012 04:10 AM in reply to: jis.augustin
    I'm not sure if you're asking about changing a single file, or about changing templates?
    To change a single existing part or assembly file, open Tools tab > Document Settings > Units tab and change units as you please.  To change a single drawing, you will probably need to create some metric styles.
    To change to metric templates as installed, Application Options > File > Configure Default Template... button.
    New Member
    04-01-2013 08:01 PM in reply to: sbixler
    Thank you very much!  I had this same question and your answer was so simple and precise.  Thanks for the support.
