• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    how do you reduce the a size default template
    73 Views, 3 Replies
    05-21-2012 12:02 PM
    I am trying to reduce the size of the a size title block, but I have not been able to. How would you resize it?
    Thanks in advance
    Please use plain text.
    *Pro
    jletcher
    Re: how do you reduce the a size default template
    05-21-2012 12:29 PM in reply to: bruce
    Right click edit definition..
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    New Member
    05-21-2012 12:36 PM in reply to: bruce
    Can you please explain ... I cannot find the edit deffinition
    *Expert Elite*
    blair
    05-21-2012 12:47 PM in reply to: bruce
    In the IDW enviroment, expand your "Sheet 1" in the browser, RMB on the "ANSI-Large" or "Ansi-A", depending on what you are using for a Title Block. Select Edit Definition".
    You should now be able to make your edits to the Title Block.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
