• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    holes in cylinder
    172 Views, 3 Replies
    01-29-2013 12:41 PM
    I'm very new at this so I'm sorry if this is dumb. I created a cylinder with a hole through the center and need to add holes through the face into the center hole and I can't figure out how. Any help would be greatly appreciated. Thanks in advance.
    Please use plain text.
    Re: holes in cylinder
    01-29-2013 12:44 PM in reply to: mbar57
    Create new workplane.
    Select one of the origin planes or axis.
    Select side of cylinder.
    Now you have a plane on which to Sketch a Hole Center Point.
    New Member
    04-24-2013 01:56 PM in reply to: JDMather
    Sorry if I seem a bit inept, but I can't seem to do this at all. I have a 1.5" dia Cylinder and need 4 holes in the side. The directions you gave aren't making much sense to me. I have tried to do the things you suggested but so far nothing. I am using Inventor 2013.
    04-24-2013 04:18 PM in reply to: ggaskill
    See image below
