• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    hole at an angle?
    64 Views, 2 Replies
    12-04-2002 10:22 PM
    i want to make a hole (drill and tap) at 10 degree angle on a surface. it is possible something like that and how?
    thanks,
    picozon
    Please use plain text.
    *Keller, Kent
    Re: hole at an angle?
    12-04-2002 11:04 PM in reply to: picozon
    you need to set up a angled workplane. If you don't have all the geometry
    you need to make the workplane, you need to use other workfeatures such as
    points and axis. Don't forget you can use the origin planes when creating
    new planes also.
    Kent Keller
    Member of the Autodesk Discussion Forum Moderator Program
    http://www.MyMcad.com/KWiK/Mcad.htm
    "picozon" wrote in message
    news:f129c28.-1@WebX.maYIadrTaRb...
    possible something like that and how? thanks,
    > picozon
    *Berry, Patrick
    12-04-2002 11:05 PM in reply to: picozon
    Sure, make a workplane at 10deg through where you
    want to have the hole intersect the plane (you may have to create some other
    work geometry first), put a sketch on that plane and then create the
    hole.
    Pat
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    want
    thanks,
    picozon
