Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
hinge
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I`m stuck at this point.I have 2 brackets which they both need cutting so as to create a hinge.The part is sheet metal formed.How does one make the cuts so as to create the hinge and also how can i flatten these 2 pieces please?
Trent
IV-2013
Re: hinge
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure how you need these cut but I attached one possibility. Look at the browser to see how it was done. As to the flat, pick a face a click on "Create Flat Pattern".
Jeff
Inventor 2013
Re: hinge
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Jeff
I also did a bit of a search and there is a cut across bend??..not sure how that works but i will try and find more info...thanks for your solution
Trent
Re: hinge
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you give a better discription of what you are trying to accomplish?
Jeff
Inventor 2013
Re: hinge
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK...1 bracket will have the middle third cut out and the other hinge will have the 2 outside cut off leaving just a third in the middle....Thank you
Re: hinge
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think you'll need two different brackets. See attached.
Jeff
Inventor 2013
