• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    Re: groove weldment (?)
    09-13-2011 04:26 PM in reply to: johnsonshiue
    Ah yes, the fillet weld works as well.
    To answer the question about Split face - you do it at the part level with either a sketch line or with a workplane.
    Please use plain text.
    Distinguished Contributor
    wolf1o
    09-14-2011 06:28 AM in reply to: cwhetten
    Now I did something with the fillet bead, but it's doing that on only one side of the cylinder - how did you mange to create it on both sides?
    Inventor 2012 Pro.
    I7 workstation
    *Expert Elite*
    09-14-2011 07:41 AM in reply to: wolf1o
    What size did you use?
    What side did it work?
    Because one of the faces is a cylinder it is very sensitive to location and order of face picks.
    I was able to do both sides without splitting the part face, but it might be worth the time to split the face if changes are likely on this part in the future (if you want it to be robust).
    wolf1o
    09-14-2011 08:11 AM in reply to: JDMather
    There's some mixup in here:-)
    1. Can you please show some screen shot on how to perform the split face - this is for the groove bead, correct?
    2. I was trying to make it with fillet bead as someone suggested in here, but could do it only on one side of the tube..Is it possible to "catch" both sides? The pic someone put in here's showing both sides..which I couldn't mimick...
    Inventor 2012 Pro.
    I7 workstation
    *Expert Elite*
    09-14-2011 08:26 AM in reply to: wolf1o
    My last response WAS with the fillet weld - I'll try to put together an animation.
    *Expert Elite*
    09-14-2011 08:50 AM in reply to: JDMather
    wolf1o
    09-14-2011 09:18 AM in reply to: JDMather
    Thank you!
    Inventor 2012 Pro.
    I7 workstation
