• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    flattering surfaces
    220 Views, 4 Replies
    01-03-2013 02:58 PM
    Hi
    Can i flattern something like You can find on the pic. ( this one is from CATIA ) or something like this. Not everything, just surface by surface. When i draw similar thing, i had problem, because i dont know how to flattern single surface, All of them are curved.
    Thank You
    Please use plain text.
    blair
    Re: flattering surfaces
    01-03-2013 04:04 PM in reply to: majusmiles
    You should spend some time on Youtube, and seach for: Inventor, +sheet metal
    There are a number of good tutorials that show different features and functionality of the Sheet-Metal module in Inventor.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Member
    flattering surfaces
    01-04-2013 01:11 AM in reply to: blair
    Yes, there are a number of good tutorials but i couldn't  find the solution, that's why i am asking, i don't wanto to bend, i wander how can i make templates and than solder them toogether.
    01-04-2013 04:25 AM in reply to: majusmiles
    A while back (4 or 5 years ago) I posted an example very similar to this.
    I will have to search a bit to find it.
    It might be better for you to attach your attempt here (modeling the geometry however you can - it doesn't have to be sheet metal).
    The solution turns out to be pretty simple.
    Member
    01-05-2013 07:35 AM in reply to: JDMather
    ok, i made it, standart.itp.,  sketch( spline), model( extrude(surface option)),circular pattern,  surface(trim,delete), convert to sheet metal, model(surface(thicken offset)), create flat patern, sometimes works strange way, probably i don't understand it enouht, :smileyhappy:
