Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
fit many sketches into a rectangle
- Highlight
- Email to a Friend
Hi!
Can anyone help me with this problem? i want to fit a sketch that is to be laser cutted. i wanna fit 30 pcs on a rectangle, is there a tool who figures out the most optimal way to fit them in a rectangle?
regards
Chris
Re: fit many sketches into a rectangle
- Highlight
- Email to a Friend
Such a problem is a mathematical nightmare. While there may be programs that could do this, you would probably be better off doing it manually -- just start with placing the largest parts onto your theoretical rectangular plate and continue placing them one by one down until you reach the smallest parts. Using 2D geometry in AutoCAD (and making individual blocks of each profile) would be best -- this would allow you to quickly position the parts (using move, rotate and mirror) or adjust them later. Just remember to leave a nominal spacing between the parts to allow for the lead-in and lead-out of the cutting torch.
HTH
- Highlight
- Email to a Friend
We use a product called Stiker Systems. It has a pretty powerful auto nesting utility. The program runs as an addon to autocad and can be used to program lasers aswell. It is not free but thats the tool we use.
- Highlight
- Email to a Friend
if your cutting something cheap like steel, do it with automatic nesting programs. If your cutting something really expensive, do it yourself in AutoCAD...
You will get less wastage from doing it yourself but if your time is worth more than the wastage savings it is better to let a program do it automatically
Autodesk Product Design Suit 2012
Win 7 Enterprise 64bit
Intel core i7 2600K Clocked @ 4.7GHz
16Gb Ram
Nvidia GTX 580
