• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    filtering partlist use filter View
    210 Views, 4 Replies
    12-25-2012 07:01 PM
    Dear Someone,
    Can help me, how to filtering a part list use view by assembly drawing, with VBA editor or iLOGic code.
    there is no class system in API for filter in partlist class use views filter.
    i use autodesk inventor 2010, and get install use ilogic add-ons 2010
    i want to get automation system for my inventor design.
    Thx.
    Ihsan Surahman,
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: filtering partlist use filter View
    01-01-2013 10:19 PM in reply to: d_great_ice
    You may want to look into the blog article in the below link for sample ilogic codes,
    http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-to-Sort-BOM-Renumber-and-sort-Parts-list/td-p...
    Hope it helps.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    Member
    01-04-2013 01:48 AM in reply to: VinodBalasubramanian
    link does not exist.
    :smileysad:
    Please help.
    *Expert Elite*
    karthur1
    01-04-2013 10:10 AM in reply to: d_great_ice
    The URL that he posted was cut off.  I think this might be where he was trying to get you.
    Try this....
    *Expert Elite*
    Curtis_Waguespack
    iLogic partslist filter, parts list filter
    01-04-2013 10:45 AM in reply to: d_great_ice
    Hi d_great_ice,
    I'm not aware of a way to set the parts list filter programatically, but what I've done in the past is to set up a parts list style that has the filter pre-set in that style, and then change the parts list to use that specific style.
    I hope this helps.
    Curtis
    'assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    'set a reference to the first drawing view on the sheet. Assumes it's not a draft view.
    Dim oDrawingView As DrawingView
    oDrawingView = oSheet.DrawingViews(1)
    'define the insert point
    Dim oPlacementPoint As Point2d
    oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d (27#, 20.625#)
    'create the parts list
    Dim oPartsList As PartsList
    oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
    'set parts list to a specific layer
    oPartsList.Layer = oDrawDoc.StylesManager.Layers.Item("Visible (ANSI)")
    'set parts list to a specific style
    oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Material List (ANSI) with Filter")
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
